Whats The Tell Tell Sign Of Your Ecu Going Out
Old Jun 26, 2003 | 03:12 PM
mazda/feed's Avatar
I have a problem with my car giving me a hard start just trying to track this down, when i push the cluch in all they way threw the floor then it starts but its more like a slow build up then it starts u dont have gear slipp but just trying to figure it out, my compression is in spec i had an integra with an ignition problem and it did the same thing cold that be it please help
Old Jun 26, 2003 | 03:17 PM
DomFD3S's Avatar
Mod Powers...gone!
That is one looonnnnnnggggggg sentence.
I've never heard of a ECU going out (at least, not for 3rd gens).
Old Jun 26, 2003 | 03:32 PM
LoveBone's Avatar
Registered Sex Offender
I didn't understand a damn thing you said. Can you explain what your problem is more specifically? I doubt it's an ECU issue though, maybe ignition related?
Old Jun 26, 2003 | 06:35 PM
scratchjunkie's Avatar
sexy no jutsu
i've seen ecu's that dont work and basically it will just keep turning the motor with nothing happening. if your lazy try getting a friends ecu and trying his out and if the problem still exists, then check out your ignition.
Old Jun 26, 2003 | 07:03 PM
BoOsTin FD's Avatar
Powered by** Rotary
it might be your clutch switch. You should check that first, even mazda diller have them and they are fairly cheap.
ZaqAtaq
Sep 5, 2015 08:57 PM
