lets see all these cars
Old Jun 1, 2003 | 01:04 AM
JadedX's Avatar
ok this is about the poll everyone that has spent over 10k show some pics on where that money is at...
no maintance bull **** i could give a **** on how many motors you go through
I'm at work i'll post some soon
hints:
paint
wheels
engine parts
motor work (i.e ported, seals etc)
inter.
exter.
Old Jun 1, 2003 | 02:14 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
Too much $, Bah!
T04S....come and gone...
Motor...
Inside...
Inside... Seats...
Old Jun 1, 2003 | 02:21 AM
wonder1and's Avatar
Rims and Rotors (5zigen Typhoon's w/ Yoka AVS ES100's & Brembo Metal)
Outside...
I guess thats about it... my sig tell the truth...
Just installed jimlab bushings, those rims, KAAZ Rear end, fixed a/c and P/S, fixing abs problem this week, will be mounting new p/s cooler, and horns.
Its just never ending,
Ryker
P.S. w/ the T04S I got 425 to the wheels in texas heat on the dyno, sitting still.
Old Jun 1, 2003 | 02:26 AM
wonder1and's Avatar
oh next... front end (C-west), greddy boost gauge, back to Single, wing eventually, do the 99 tail lights, fix exhaust leak, paint calipers, lots of polishing.... oh yeah, sleep.
Old Jun 1, 2003 | 03:03 AM
JadedX's Avatar
very nice wonder1and
**** looks good
Old Jun 1, 2003 | 03:08 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
That's what I'm talking about... Nothing like PROOF!
Old Jun 1, 2003 | 03:49 AM
r0t0r-rooter's Avatar
call me Smokie Smokerson
I got receipts.......
Old Jun 1, 2003 | 04:09 AM
maxcooper's Avatar
WWFSMD
http://www.maxcooper.com/rx7/my_car/index.html
Read it and weep. I do.
-Max
Old Jun 1, 2003 | 04:55 AM
Jasooner's Avatar
From: University of Oklahoma, Home of the ranked #1 Sooners!
Holy cow... you guys are hardcore
Old Jun 1, 2003 | 02:35 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
wonderland, hate to bother you...but can you give me some more info on your seats? THANKS!
Old Jun 1, 2003 | 02:54 PM
apexkw's Avatar
in slow, out fast!
93 rx7 touring
Apexi GT Spec Exhaust
Apexi RX6 Turbo Kit @ 15psi
Apexi GT Spec Intercooler
Apexi Wastegate Ported By XS Engineering
Apexi Power FC
Apexi Power FC Commander
Greddy Pully Kit
Greddy Autometer Turbo Timer
Fluidyne Radiator
Magnacor Wires
NGK Platinum 9 spark plugs
Defi Bf Boost Gauge
Defi Bf Water Temp Gauge
Defi Bf link unit
NipponDenso Fuel Pump
550cc Primary Injectors
1300cc Secondary Injectors
Modified Secondary Fuel Rail
Heat Wrapped Exhaust Manifold and DownPipe
Ceramic Coated Downpipe
Ceramic Coated Intercooler Pipes
Pettit resonated Midpipe
Blitz Blow Off Valve
Blitz Power Meter II
Blitz SBC ID II
Tein RE/ Pillowball Mounts
HKS Twin Power Ignition
2001 RZ Recaro seats carbon kevlar
2001 Nardi steering wheel
C's Short Throw Shifter
Border Gauge Pod
Feed engine torque brace
Tan to Black interior conversion.
Repainted interior...around gauges,hvac, and shifter
99 JDM style tail lights
RE toe end links
RE trailing arms
Act 6 puck extreme
Relocated optima red top to rear bins
more stuff to come......next on my hit list is wheels
Old Jun 1, 2003 | 05:38 PM
DrPJM1's Avatar
Hurley 2mm 2 piece long-life racing apex seals
Street port -no lumpy idle
Exhaust port -no boost creep
Eccentric shaft plug -allows oil lubrication at all times
Silicone coolant and oil bearings
Block off plates:
AWS -3k idle when starting the car
EGR -recirculates exhaust gases to intake
ACV -directs air to air pump
Air pump removal -pumps air into the exhaust
Power Steering pump removal
M2 Intake System
M2 Medium Intercooler
M2 Intercooler Hard Pipes
New Silicone couplers
Greddy elbow
Larger Drive Pulleys:
Main, Alternator and Water Pump
Bönez Street-Comp Clutch
Bönez 9 lb. Aluminum Lightweight flywheel
Mazdaspeed Short Shifter
Mazdaspeed shift select spindle
Midpipe (no pre-cat)
Downpipe (no catalytic converter)
Apex Dunk Exhaust System
Fluidyne High-Performance radiator
WideBandO2-Tuned Apex Power-FC w. Commander
Apex Turbo Timer (Amber Lighting)
Cusco Front Strut Bar
Crooked Willow Sway Bar Mounts
HKS Hyper Dampers (Coil-overs) 25in to wheelwells
Goodridge Braided Stainless Steel Brake and Clutch lines
180-degree thermostat
A.S.T. tank removed
51R battery
Custom Aluminum Battery Tray
Fan Modification Switch -runs 10 min after shutdown
M2 harness bar between rear strut towers
intake air temperature (IAT) sensor moved to Greddy elbow
HKS TwinPower
Alpine Stereo
& soon some Sparco Milano's
Old Jun 1, 2003 | 07:25 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
apexkw...uhmmmm, those seats are ****** badass!!
Old Jun 1, 2003 | 07:42 PM
Mahjik's Avatar
Mr. Links
Uhh, you got those backwards....
Old Jun 2, 2003 | 01:29 PM
DrPJM1's Avatar
My mistake. (So shoot me!) Joke : )
Old Jun 3, 2003 | 09:33 PM
jpandes's Avatar
click sig
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
