1 full tank= 150miles WTF
Old Apr 22, 2003 | 02:15 PM
monte143's Avatar
double post
monte143's Avatar
i had really good luck the last time i asked for advise from everyone, now i need help again. even when i first bought the car and did a tune up, ive been getting really crappy gas mileage. ive asked acouple people in my area about how many miles to the tank they get, they both say around 300. what could be wrong with my 7. is this a sign of something worse to come.
thanx everyone
monte
Old Apr 22, 2003 | 02:43 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
First off, it all depends on how you drive
A friend with a firebird can drive all week on a tank of gas if hes nice, or he can kill a 1/4 tank one morning on way to work if he gets on it
your profile says you have an 88 GXL, is this still right?
What have you replaced? the first thing i would check would be the O2 sensor
Old Apr 22, 2003 | 02:48 PM
monte143's Avatar
is there a way to actually check the o2 sensor
Old Apr 22, 2003 | 02:57 PM
REFLUX's Avatar
www.v8less.com
300 MILES per tank???
i get something like 300 KILOMETRES (~140miles) per tank
i have a TII tho......
Old Apr 22, 2003 | 02:59 PM
Center of The Universe's Avatar
Yeh in my NA i get about 250 - 300, if i drive light on the freeway.
Old Apr 22, 2003 | 03:03 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
The most I got was 315 on a tank.
Usually I get 300 to the tank. I pre-mix though.
Bruce's Avatar
If you have a haynes manual it tells you how to check to see if its working properly.
Old Apr 22, 2003 | 03:12 PM
rotaryrules's Avatar
monte- I feel your pain. I have an 88 gxl which runs well, knock on wood. But i too was getting 125 miles on a full tank. Before I changed the fuel filter I was averaging about 60 miles on 11 dollars of 87 fuel approx 5.1 gallons- now since I changed the fuel filter im at about 80 miles- not a bad improvement , but by no means economical. Im lookin to replace more parts in order to improve my gas mileage---Good luck , and let me know if you come up with anything---Ren
Old Apr 22, 2003 | 03:18 PM
monte143's Avatar
double post
Old Apr 22, 2003 | 03:32 PM
Icemark's Avatar
just replace it, it is only a $25 part.
If you are getting that bad mileage, but the car starts and runs fine other than that, then you need to do a full tune up, including all filters (oil, air, fuel), spark plugs and cables, change the coolant, change the oil in the engine and driveline, belts, and the O2 sensor.
Old Apr 22, 2003 | 03:51 PM
i dug around some of my notes from when i got my 87 base, i was getting 290 a full tank, i probably could of goten more but where i live there are alot of twistys. hard to resist
on another side note
my current beater, a 94 Geo XFI got 330 miles on its last tank of gas, all $11 of it
Old Apr 22, 2003 | 05:12 PM
Whahahahahoo Dear god thats awsome....
Old Apr 22, 2003 | 05:51 PM
rx-7s rock's Avatar
Game of Death
I get around 250 to the tank. I did get 350 miles to the tank one time. After I changed my fuel filter, the gas mileage got better. Oh, and do what Icemark says, he's a good/smart man.
Old Apr 22, 2003 | 06:45 PM
Rx-7Addict's Avatar
Rotary Powered
I get about 150 miles on a 15 gallon fill-up
Join the shitty gas mileage club
Old Apr 22, 2003 | 06:54 PM
Joonas's Avatar
WTF Premixxing dosent give you better milage does it?
Old Apr 22, 2003 | 07:01 PM
Raymr's Avatar
Check everything! Check the AFM, TPS, all sensors and solenoids, and everything else that you can get specs for. The car might run OK if one or 2 of these components are out of whack, but it could cause way too much gas being dumped into the engine. I finally have everything within specs and I'm getting at least 20mpg now with daily redlining.
Old Apr 22, 2003 | 08:08 PM
EvoDraZ's Avatar
C-Weed
i have an 88GXL and i get about 250 if lucky also i tend to drive a bit hard but i average about 50-60 on roads and like 80 on freeway.
i cant help it its where the rpm's feel right @ home on the 3000 mark :P. also i just started premixing.
Old Apr 22, 2003 | 08:14 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
my gas tank is 1/3 full right now and my odo says that I've put on 103 KMs... that's about 150KM per tank.. thats NINTY MILES! beat that!
Old Apr 22, 2003 | 08:18 PM
skyypilot's Avatar
My car gets around 20 MPG in normal driving. Pretty poor for a 1.3 liter car.... Not that I care!!
Old Apr 23, 2003 | 02:16 AM
monte143's Avatar
well icemark ive changed everything on your list except the fuel filter and o2 sensor. i picked those up today before work. i squirted the O2 sensor with PB blaster before and after work, so hopefully i can get to that tomorrow before work. ill keep everyone posted to see how this changes things. thanx again, everyone
Old Apr 23, 2003 | 04:26 AM
Rx7Nub's Avatar
TII 4 SALE!
220-260km's a tank here, i gotta get me a new O2 sensor...
Old Apr 23, 2003 | 08:45 AM
1987RX7guy's Avatar
Well my friend before pre-mix I got 280 miles to the tank after i get 300-315 to the tank. We believe that it is several things that contribute to this: I am a bit leaner because of the oil in the tank replacing some fuel, the plugs are not getting all that nasty build up on them cuz it burns cleaner, and less carbon overall.
I am happy with pre-mix cuz it saves me cash.
P.S. gallon of gas=1.36 dollars 16oz of pre-mix=95 cents saves me 41 cents a fill up.
Old Apr 23, 2003 | 09:22 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
I get about 270km on 55liters of 92octane which is around 12.1MPG
Recently I noticed that My car doesnt have a O2 sensor, I guess that the former owner took it out when he put in the headers. I fixed the loose connection at the Water Temp. Sensor that was a little improvement and she doesnt fart so much more now that she is on a diet
Old Apr 23, 2003 | 10:51 AM
Node's Avatar
opening up your exhaust will give you better gas mileage, if you can resist pissing it away having fun
i wonder what other performance mods can help out with gas mileage?
my base is so untuned it gets garbage mileage, definately needs o2 changed and fuel filter.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
t-von
Sep 10, 2015 01:56 PM
