Dynoed 460atw
Old Dec 19, 2002 | 11:04 PM
LETHAL RX7's Avatar
Dynoed 460atw
Just had a chance to post this up. got back from KDR the other day and dynoed 459.5 at 18 psi on c16 and 419.2 at 16 psi on regular 94 oct. Its street ported t78 powerfc and all the other bs that goes along with it. we tried turning it higher but it started bleeding off at high boost so we called it a day bc it was about 7 at night and we were there all day. So i fixed some things and ill go back up sometime this month to try again for the 20psi+ pulls. Laters
Old Dec 19, 2002 | 11:27 PM
Jeff20B's Avatar
Lapping = Fapping
Does atw mean rear wheel HP or something? Good run.
Old Dec 19, 2002 | 11:45 PM
Manolis_D's Avatar
At The Wheels
Congrats -- nice numbers. Do you have any more info on the setup (or a link to some mods)
Lookin' good!
-Manolis
Marshall's Avatar
atw = at the wheels
Old Dec 19, 2002 | 11:53 PM
maxcooper's Avatar
WWFSMD
Nice numbers!
-Max
Old Dec 20, 2002 | 01:06 AM
lane_change's Avatar
It has begun
I hope to put down numbers like that when I get my car dynoes this spring. We'll see. I am also running a Race Ported motor, T78, PFC, etc..... I am hoping to do a 20+ run as well. I would love to break 500rwhp but I doubt it at first. Maybe later.
Old Dec 20, 2002 | 05:56 AM
Judge Ito's Avatar
congrats on the numbers..
Old Dec 20, 2002 | 09:34 AM
EricM's Avatar
Maybe XSPOWER can correct me if I'm wrong but I believe you need PowerFC software(PowerExcel???) to tune it above 20 psi. But I guess 20 psi on that motor would be very close to 500 rwhp, that should be enough for most people.
congrats on the numbers btw...
Old Dec 20, 2002 | 02:12 PM
ErnieT's Avatar
Living life 9 seconds at a time
What map sensor do you have for the power fc? The stock one is only good for 17lbs, unless you've got the 3Bar. Also, post your dyno sheet, I'd like to see it.
Old Dec 20, 2002 | 02:30 PM
vosko's Avatar
Just Call Me Terminator!
nice numbers. DYNO SHEETS!!!!
Old Dec 20, 2002 | 05:08 PM
nocab72's Avatar
03 Cobra Killer
nah, you can modify the pressure map with a datalogit after installing a 3bar map sensor and goto 30ish psi...(ie don't need powerexcel software)
BTW: nice numbers, I third the dyno sheet request...
K
Old Dec 20, 2002 | 07:36 PM
88IntegraLS's Avatar
Displacement > Boost
That thing is a MONSTER!!!!!!!!!!!!!
My FC has an engine problem and I am stuck with my 1.6 liter 88 Acura Integra with probably like 80 FWHP!!!!!!!!!!!
AAAAAAAAAAAAAAAAAAAAHHHHHHH!!!
Old Dec 20, 2002 | 07:59 PM
80-CU.IN.T's Avatar
Very nice numbers - 4th dyno sheet request
Old Dec 21, 2002 | 02:11 AM
LETHAL RX7's Avatar
It has the 3 bar map sensor. Yes its at the wheels..Ill try to get someone to post the dyno sheet i have no way to do it but ill see if a friend can. Ernie i am the guy that you took the pictures of my cage at maple grove, the end of oct. Once the boost bleeding prob is solved we will go back for more any questions feel free to ask. laters
Old Dec 21, 2002 | 07:48 AM
ErnieT's Avatar
Ahh! Good to put a face with the name. I thought you had a Greddy TD04 (the small kit)??
Curious, your mph and et's were in the low 12's with a rather low mph, especially for 460rwhp?? With that much power, you should be high 10's running high 120's mph.
Old Dec 21, 2002 | 09:30 AM
LETHAL RX7's Avatar
Well ERNIE when i was at the track i was at 15 psi on regular 94 oct gas and i went 11.6s at 118. I JUST got off the dyno. Hence the new numbers. So once some tracks open ill have some 10 sec slips to show ya.
Lates
Old Dec 22, 2002 | 08:02 AM
ErnieT's Avatar
Lates
Im just trying to add this up. At 15lbs you ran 118mph, putting your power around the 375rwhp mark, so your saying with 3 more lbs of boost you picked up almost 100rwhp????? Remember Im just doing the math here with your mph. Since I drag race alot, it easy to figure out about how much power you make looking at mph.
Also, you say you made 40 rwhp more with only 2 lbs of boost more, going from 16-18psi? Sorry bro, I find this hard to believe.
This would be alot easier if I could see your dyno sheet. Thanks, and congrats....
Old Dec 22, 2002 | 12:44 PM
LETHAL RX7's Avatar
I changed the ignition and injectors..so the ignition cleaned up alot of probs i was having and what i wrote the car has done. I am not some first time racer either..so you have nothing to teach me.and everything that i stated the car has done. i have no reason to lie about what the car does or makes. so there it is. Thanks to everyone else who can just appreciate what someone does and doesnt have to contest it....its funny how vosko says he made 413 or something at the wheels at 13 psi but noone had anything to say about that.(not a dig to vosko) this is just a for instance.
peace
Old Dec 22, 2002 | 12:52 PM
ErnieT's Avatar
Nobody said anything to Vosko to contest his numbers because he posted his dyno sheet! And I wasn't trying to teach anything. Was just stating what I knew from mph in the 1/4 mile. It's just math.
Old Dec 22, 2002 | 07:51 PM
vosko's Avatar
i made 416rwhp @ 13psi
Old Dec 22, 2002 | 08:11 PM
crispeed's Avatar
'Tuna'
I have to agree with ErnieT on this one!
I've said this many times before. It doesn't matter how much RWHP or on what type of dyno you made it on.
One thing that's 99% correct or the same everywhere is the length of the 1/4 mile and the numbers on the time slip after a run. It's basic math because it takes a certain HP to move a given weight to do a certain MPH!
crispeed
87 RX-7 TII
9.204@150.47mph
2600lbs
un-tubbed
Old Dec 22, 2002 | 08:30 PM
artguy's Avatar
WTB** Very Low Miles 94-95
gosh...i love drama.
lets see the sheets!
email them to me and I will post them for ya
jasonmanley@onebox.com
j
Old Dec 22, 2002 | 10:39 PM
LETHAL RX7's Avatar
Ill get them one way or another posted. either way you will still se the same hp i told you. and i know that the end result is at the track and the mph shows the real power of the car im not arguing that. Im not even gonna get into a bunch of bs over this ill get the sheets on here one way or another and when you look at them i guess somehow it will make this all better.
Later
Old Dec 22, 2002 | 10:48 PM
vosko's Avatar
we are jealous of unproven dyno numbers...
Old Dec 22, 2002 | 11:28 PM
artguy's Avatar
i said i would put them up...just drop me an email with the sheet and Ill host it on my website for you.
j
