MOOWING sound is so bad!!!!
Old Aug 11, 2002 | 08:57 PM
puma's Avatar
canadian monster
ok guys, i just finished my custom intake which is basicaly identical to the hks racing suction.
Anyway, i just put a small k&n on the air pump and i knew i would get the mooing sound but MAN!!! it is so loud... i can't drive like that, everyone thinks i have an hidden dragon under the hood that is waiting to come out.
what have you guys done with yours open intake? Is it different when it goes behind the air filter? i can't beleive that people can drive with that sound. I suppose that unplugging the air pump is not a good idea since i still have my main cat.
please tell me something.
man i love this board, thanks a lot
puma
Old Aug 11, 2002 | 09:09 PM
MastaCow's Avatar
Apexi Power Intake has a restrictor pill that goes in the hose to the air pump.
Basically a chunk of aluminum that fits in the hose with a small hole drilled thru it to reduce the flow into the air pump.
Sounds like you have a relatively free flow of air to your air pump.
Hope this helps.
Old Aug 11, 2002 | 09:27 PM
puma's Avatar
canadian monster
yep that really help because i drove my friend's car and he has that apexi intake and i didn't hear that sound.
yes i have a free flowing intake on the air pump, i have a small k&n breather right on it.
maybe i should put some restriction there...
Old Aug 11, 2002 | 09:38 PM
Chaz's Avatar
I recently did a similar custom intake job and currently have the "Moo" sound but mine isn't horribly loud. I still plan to fix it ASAP though. Someone on the forum had mentioned that you can purchase a small lawn mower muffler from Home Depot to get rid of this sound. I plan to check out what they have and see if this is possible. Thought you might like to check it out as well and see what kind of luck you may have with it.
Old Aug 11, 2002 | 10:53 PM
spoolin's Avatar
do away with all your cats, get dp and mp - if you've got a dragon under the hood, you need to let him shoot his flames!!
Old Aug 11, 2002 | 11:08 PM
JConn2299's Avatar
reliable performance
Put a pair of cattle horns on the hood like the guys in Texas do.
Old Aug 11, 2002 | 11:18 PM
I put a lawn mower silencer but it was still quit a moo
so I put some steal wool in to the silencer and no moos anymore.
Old Aug 12, 2002 | 12:26 AM
Pumped's Avatar
is it ok to plug it up completly and not put on the small k&n breather filter?
the reason i ask is that when i had my pettit intake i had a breather on there and there was mooing.
now i have the arc intake and it plugs the hose up, but no mooing.
Old Aug 12, 2002 | 09:53 AM
93 R1's Avatar
You guys have it all wrong.
Who wants a ******* lawnmower muffler under their hood?
Go to the parts store and get a valve cover breather for an american car. They should have a large selection just find one with an inlet that is the same size as the airpump hose.
Mine is black plastic and is a circle that is about 2 1/2" round. Its not very noticable and I'm sure that it looks alot better that a muffler. You don't hear any mooing.
It cost me like 89 cents
Old Aug 12, 2002 | 10:36 AM
Chaz's Avatar
Thansk for the info 93 R1. This sounds like a better option than the lawnmower muffler. I'll check it out and give it a try.
Old Aug 12, 2002 | 03:47 PM
jpandes's Avatar
I have a custom CAI also. At first I had the airpump outflow(metal tube to the right of the upper intake coupler)venting to the engine bay and the mooing noise was horrendous! The out flow from the airpump is making that shitty mooing noise, not the airpump intake.
What i did was stick about a foot and a half of 1" hose that I had laying around on the tube and run it down toward the gap between the radiator and the body. The noise practically all but went away.
my .02
Old Aug 12, 2002 | 07:53 PM
puma's Avatar
canadian monster
are you talking about the top of the two metal tube that are attached to the lower intake manifold? that would be where the sound come from? i put a small k&n breather there too.
Old Aug 12, 2002 | 08:49 PM
R1Outcast's Avatar
Okay, maybe I'm just totally confused, but are you talking about the noise that the air pump makes? If so, then just unplug the air pump.
Old Aug 12, 2002 | 09:39 PM
BoOsTin FD's Avatar
Powered by** Rotary
That moooing sound doesn't come from air pump, It comes from that pipe next to the air pump. It's one inch pipe and the restrictor pill that comes with apexi power intake goes in there. I didn't get the pill when i purchased my intake so i made one myself. I just bought one inch of pluged metal tube and drilled small hole in it and put it in that hose. The mooing sound completely went away.
I hope that helps you guys.
Old Aug 12, 2002 | 09:56 PM
puma's Avatar
canadian monster
hmm well i guess i'll try that
the problem with unplugging the pump is that it won't work, making the main cat clog itself
Old Aug 13, 2002 | 02:34 PM
R1Outcast's Avatar
Originally posted by puma
...the problem with unplugging the pump is that it won't work, making the main cat clog itself
Oh Great. That's probably why I'm not getting full boost now. Oh well, the midpipe and Home Depot boost controller is going on next week.
Old Aug 13, 2002 | 02:51 PM
ViraResearch's Avatar
Where does that pipe go?
Old Aug 13, 2002 | 03:09 PM
BoOsTin FD's Avatar
Powered by** Rotary
I dont' know where that pipe exactly goes, but you should search that's how i found out hot to quiet that sound and how the sound is coming from that pipe, cause i guess it doesn't want a lot of air or something.
Jim Calandrella's Avatar
The Ricer Eliminator
You know, I guess i'm crazy. I don't mind the moo noise. It confuses people, and makes them a little scared to go. Only a select few(non rx7 owners) knew what it was when they heard it .
I know.
I'm wierd....
Old Aug 13, 2002 | 03:26 PM
jpandes's Avatar
Yup, I am. That pipe is normally connected to the OEM airbox via a one inch, 2.5' long hose. and with out it it makes the mooings noise really loud.
I also had a breather element on it for a while, but figured out that it was an out flow and didn't need a filter.
Old Aug 13, 2002 | 03:29 PM
I took my non rx7 friend for a ride today and he asked if something was wrong with the car when he heard it. Not the impression I'm shooting for. Of course I responded "hmm maybe lets see" and took him up past 100 with him gripping the grab handle the whole way. After that he stopped asking questions about the car-and everything else.
Old Aug 13, 2002 | 03:36 PM
That'll learn em'.
Old Aug 13, 2002 | 06:09 PM
puma's Avatar
canadian monster
you see, that is exactly why i want to remove that sound, not for me, because i know it is armless.
i already have trouble explaining what a BOV is when they hear the sound, if i have to explain what is an air pump on top of that...
jpandes, thanks a lot, that is the kind of info i needed. i'll try that out. I too though air was entering from there but thinking about it and looking how the air box is made, it makes sense. Otherwise, the air coming from there would have not been filtered.
thanks again
puma
Old Aug 14, 2002 | 07:31 AM
blackscorpio's Avatar
#1 F0RUM TROLL
Another solution is to get rid of the airpump. No more mooing.
Old Aug 14, 2002 | 10:02 AM
RyanREX's Avatar
Killer Turbo Twins
I have had the moo for awhile, I actually got used to it.
