N/A GSL-SE turbo project
Old Oct 12, 2005 | 04:58 PM
Tsi_Xtreme's Avatar
1972 Rx2/1988 Rx7 TurboII
I'm currently serving overseas and bough my new SE on my R&R leave. I knew I wanted a faster SE because I had owned and autocrossed one, one year eariler. I love the way it feels but it just doesn't have power so I decided it had to have a turbo. I thought about a TII swap however I want to do the engine build myself and I want to be able to race when i get home so I decided to let Ludwig Motor Sports take care of my build. Here is the current status of my build.
Old Oct 12, 2005 | 05:03 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
looks pretty good so far. Hey when you get back I am about 4 hrs from you i think. I am in Cross Lanes WV and I am planning a meet for the tri state area. Just wanted to see if you know nebody around your area that would be interested in coming.
Tsi_Xtreme's Avatar
Next year I'll be building a Turbo II engine and intalling a TII tranny, this N/A setup is just to hold me over for awhile.
Old Oct 12, 2005 | 05:06 PM
Tsi_Xtreme's Avatar
I'm sure many here would attend.
www.kyrotary.com isthe local KY rotary forum. Just post a event date in the meet section.
Old Oct 12, 2005 | 06:22 PM
z-beater's Avatar
REW'd FB
What IC is that?
Old Oct 13, 2005 | 07:10 AM
Tsi_Xtreme's Avatar
Its a IC from ebay. New and cost me about 250 bucks. My friend used one on his TII FB project and worked well so I bought the same one.
Old Oct 15, 2005 | 04:27 PM
Tsi_Xtreme's Avatar
update...
Old Oct 15, 2005 | 06:47 PM
toxic_d's Avatar
What intake is that?
Old Oct 16, 2005 | 06:55 AM
Tsi_Xtreme's Avatar
Its a S5 intake. The lower part of the intake has been modified for the turbo to fit. Ludwig Motorsports figured out a way to make it work by cutting the ACV and 6-port actuator mounting bosses off the intake he gained enough clearance. He then spent some time with a die grinder going over the intake to clean it up and make it look nice. He then took it to a welding shop to have the vacuum holes and the holes left from the 6-ports plugged up with some nice TIG work. After that he media blasted it to make it look factory new.
Before:
After:
It turned out really nice!
Old Oct 16, 2005 | 09:27 AM
rotariesrule's Avatar
what turbo manifold it that?
Old Oct 16, 2005 | 04:10 PM
Tsi_Xtreme's Avatar
its a S4 exhaust manifold with a custom spacer to allow room for the turbo
Old Oct 16, 2005 | 04:21 PM
FB II's Avatar
i take it there will not be an intercooler on this setup?
Old Oct 16, 2005 | 04:26 PM
Tsi_Xtreme's Avatar
yes there is, look in the second picture. Its right in front of the radiator. The piping configuration is going to over lap, which sucks ***, but a TII intake wouldn't fit with out some crazy modification. So it has to be on the same side.
As far as everything else.
I'm using 680s for the primary injectors and 1600s for the secondaries.
Warblo 255lph fuel pump
S5 coils
Tial Blow off Valve
Old Oct 16, 2005 | 11:29 PM
Tsi_Xtreme's Avatar
Update: Here's the way the intercooler setup will be. The charging pipes are going to be powder coated before final installation.
Old Oct 16, 2005 | 11:38 PM
FB II's Avatar
ok awesome, sorry i missed that. i'd get an air temp gauge tho because unfortunately with those pipes overlapping there is still going to be alot of heat soak but definately not as bad as without an i/c. Lookin good bro!
Old Oct 17, 2005 | 05:13 PM
jacobcartmill's Avatar
just dont care.
it has a huge FMIC, and haltech has an intake air temp gauge...
Old Oct 23, 2005 | 05:17 PM
Tsi_Xtreme's Avatar
update...
The Haltech is done. My builder is waiting on exhaust gaskets he forgot to order. When they arrive everything will be bolted together for the final time and he'll start it up. The engine work is basically done. He is getting the gauges finished up tomorrow. He'll be ready to hit the street for a shake down Monday if the gaskets show.
Last time apart and haltech wiring finished. I really need to clean that engine bay when I get back to the states!
Old Oct 23, 2005 | 08:32 PM
brandon davis's Avatar
Id say so too that is one dirty engine bay. Should be fun though I cant wait till I turbo my SE.
Old Oct 23, 2005 | 09:02 PM
Jose Feliciano's Avatar
chosen 1
are you doing a rebuilt or stock gslse rotors how much boost
Attached Thumbnails N/A GSL-SE turbo project-maz1.jpg
Old Oct 24, 2005 | 09:45 AM
Tsi_Xtreme's Avatar
The engine has mileage on it, about 160K. I don't know how long its going to stay in one piece. I plan on pulling the engine in the spring to do a freshen up on it. Clean, paint, new gaskets, apex seals, water pump, and a nasty street port. Its going to be low boost. I think my builder said about 7psi, whatever the wastegate will allow, not adding a boost controller to up the boost.... Yet!
Old Oct 24, 2005 | 09:20 PM
RRTEC's Avatar
Rotartist
What was your final cost?
Old Oct 24, 2005 | 10:36 PM
Paradox's Avatar
backyard tuner
ya i definetaly wouldnt have gone for a side to side flow i/c like that, that extra piping is going to kill you and cause more lag.
overall looks like it'll be damn fun tho!
Old Oct 25, 2005 | 09:29 AM
Tsi_Xtreme's Avatar
don't know yet... still costing. The build is costing me a pretty penny, supposed to be about 40hrs of labor for installation of everything and tuning... the builder charges 30hr so about 1200 for labor. I have about 3K just in parts. I still have to get the rest of the exhaust and some new Falken Azenis RT-615's to go on my new rims I bought. Plus looking to spend about another 600 for suspension. So I'm sure by the time I'm done I more than likely could have bought a 3rd gen.
Old Oct 25, 2005 | 09:32 AM
RRTEC's Avatar
Rotartist
Tsi.. what kind of #'s are you expecting?
Old Oct 25, 2005 | 09:48 AM
Tsi_Xtreme's Avatar
I'll be happy with 200whp, but I'd like to see 250whp. Not looking for crazy horsepower... just more than 135. Its going to be dyno'd when completed so i'll let you all know how much it ended up with. Used to have a SE about a 2 years ago that I autocrossed. I loved the car and how it handled but honestly it just wasn't enough power around the track to get where I wanted to go so I sold it and bought a SRT4. It has great power and handles great around the track, however it's FWD and I love the loose and out of control feeling the RX7 had. Plus I HAVE to be different... don't know always did so instead of buying a TII or a 3rd gen I had to have another 1st gen with a turbo. I was hooked to the first gen after owning one. Don't really car for the body on 2nd's, LOVE 3rd's but lets face it... really expensive and I'd have to mod it which would have been even more.
