Received quote for a 4 rotor engine or eccentric shaft.
#43
on
lets try again
block: 28000
turbo & kit
Custom Manifold: 600
Custom Downpipe: 300
Wastegate HKS Racing: 450
Turbo itself: 1200
Oil Lines, fittings, etc: 100
clutch 2disk & flywheel 1500
1000HP fuel pump 300
BOV 200
IC 1000
Custom IC piping 500
Engine Mounts 500
FD Subframe 1000
4 more fuel inj 800
8 ign. coils and wires 400
High performance radiator 400
Haltech E6K 1100
Custom anti-sway bar 600
Tranny mount 30
Driveshaft 200
AEM C2DI 8 ch Ig amp 450
Oil pump/lines 500
Alternator/bracket 200
New rims + tires 3000
Rear Wheel flares 300
Kaaz differential +oil 860
Mazda reinforc. PPF 450
Chromaloy axles 800
I think we are closer, but we aren't their yet. I think there are fuel lines, rails, and oil lines, extra oil cooler, etc
needed.
Lets throw in some more 4000
49740 w/o tax
block: 28000
turbo & kit
Turbo itself: 1200
BOV 200
IC 1000
Engine Mounts 500
FD Subframe 1000
4 more fuel inj 800
Haltech E6K 1100
Tranny mount 30
Driveshaft 200
Oil pump/lines 500
Chromaloy axles 800
needed.
49740 w/o tax
#44
on
Does anyone else think $28k is a bit ridiculous for this motor? Kind of hard to justify when you can get a 3-rotor for around $5k and make all the horsepower you could ever want in a street car.
Instead of comparing the cost of doing a 4-rotor install yourself w/ Pettit's deal, you should be comparing the price difference between a 3-rotor or 4-rotor install assuming you do it yourself. With Pettit's deal you will get a well-sorted car that's ready to drive. Doing the 4-rotor install yourself, you will probably end up with a clusterf*ck and a 3 year project.
#45
You look and a 650HP PP short block and decide it needs a turbo kit? I think 99% of FD owners would be happy with a NA street ported 480-odd HP four rotor.
-pete
-pete
#46
on
I wish I had enough money for a 4 rotor FD ( I don't know anyone that does)
I am working on a 20B 3 rotor conversion myself, and thats a big pain in the ***, let alone adding another rotor housing and side housing into the mix. Think about it this way gents, if its based on the mazda 4 rotor 26b (using the rotors and rotorhousings from a 13b) its going to be long as ****. You will have to either adapt the subframe to mount the engine aft of the steering rack. or relocate the steering rack and fab some new spindles to correct the bump steer problem that will follow. So realisticly, your cuttin the firewall too. Fabbing a new tranny tunnel. Doin a lotta trail fitting. so lets say even if you do most of it yourself your lookin at about 2 months of work just for the subframe. and for engine management its going to be a bitch. cause the 26b that i know of from the Le Mans Road racing cars has a variable geometry intake that changes based on RPM and its an NA motor. Yes i said NA. lol. so your looking at another 6k like it or not just for the ECU, like a Motec M8 or the M880. plus the money to fly one of the tech reps out to help you play with it and tune the damn thing at a cost of 600 per day, plus 275 per day of travel, plus a nice fat fee for comin and spendin time with ya. (not like i have done that lol) Don't bother with halteck there. then add about 1500 for the wiring harness alone, plus ignition, add another 500 in connectors.... can ya see where this is going? and i dont know about you, but i wouldn't run a 300 dollar radiator on an engine that cost me that much hell the SR radiator that i have for my FD was 500, so i would go to CR racing to have them fab me a radiator, at a cost of about 1200 big ones. (they make radiators for nextel cup cars and CART racecars). so that leaves us with a helova lot left. so ya still dont have a clutch, so your lookin at an AP racing 3 disc 5.5inch carbon/ carbon clutch, cause anything else would get nuked. thats about 2 grand, a driveshaft would be the cheep part at about 500 bucks. i would laugh at ya if ya tried to run the stock rear end. not to mention a tranny that could hold up to the torque and abuse that the 26b is capable of throwin downabout 500 lb ft of torque. so if you want it to last your lookin at the low end of a hewland Sgt 5 speed and thats 7 grand, but since we are goin to excess we might as well throw in a IGT-C 6 speed and it actually has 7 speeds, 6 forward and one reverse and it was the same tranny used in 90% of the japan GT300 cars in 2002 . now for 11,000 bucks i would say that was a deal lol. but seeing as the SGT is only rated at 450 Lb Ft of torque you might as well get the IGT-C.
so lets just see where that puts us.
-28,000 for the engine and god ***** you the variable intake with the deal, hell lets say its on sale for $26,000
-ECU $6,000
-a$$hole from motec to help you tune the damn thing at least $1200 min
-$2,000 for wiring harness, sensors and other shyt
-1200 for radiator
-$2000 for a 3 disc carbon/carbon clutch, more if you want to have a costom sprung disc clutch made for you so you can try to drive the damn things on the street
-$500 for a custom driveshaft
- and 11,000 for a tranny that wont **** itself, dont forget to add about 700 plus for a costom bellhousing.
-$49,900 without belhousing, subframe or a whole lotta anything.
so lets all sit down and think about this. it might be a better deal to take your FD to acosta and hand them your FD and a check for $38,000 and a couple months later they hand you your FD back with a 500-600 hp 20B on low boost and pump gas with a top end of 800 hp on C16.
-ECU $6,000
-1200 for radiator
#47
on
Originally posted by ReodDai
It could be just me but me giving someone $40k and having them give me a car that RUNS 11s back, sounds alot better than me giving someone $40k and they give me and engine and a note that says "Good luck" in a random oriental language.
If I'm giving someone forty thousand dollars to make my car faster, it SURE as hell better run faster than 11's!!!!
#48
on
Gargamel and 4 rotor sub frames
are you kidding man? lol a subframe that drops it down enough that you dont have to modify the firewall.... first off... no such thing, i know someone here in SD that is doing a 4 rotor single turbo, yes 4 rotor single turbo and there is no way in hell that you could build a subframe without touching the firewall unless you put the steering rack on the bumper. lol. and if your doing it for better performance, why would you stick a 4 rotor in there unless you just drag race, but for the sake of argument, you want to have a 4 rotor road race sort of thing goin on. wouldnt you want to maintain the fuxin sweet ballance the FD has? so move the thing back, WAY back, note get it to close to the firewall and your right leg will cook on long drives in the summer (i know just a little about that lol)
#49
on
cavellm- and ten second cars
cavellm- with 600 hp, sintered metalic or carbon clutch, M300 axles, a couple spair trannies and some 285's outback you could lay down some 10's lol
#50
on
Re: Gargamel and 4 rotor sub frames
#53
on
Originally posted by rzograbian
ive seen a 4 rotor on a 3rd gen and i was wondering since the motor sits soo low, how do they change the plugs?
#56
on
DISCLAIMER: 1:30 am drunk post
4 rotor engine = 28000
custom manifold = 2500
2 gt42rs = 4000
everything else to run = 20000
severe traction problems = 0
most unique and powerful FD ever = priceless
2 gt42rs = 4000
#59
The following users liked this post:
mr2peak (09-17-21)
#61
I'll blow it up real good
Unfortunately, none of my pics show access to the plugs but iirc, it wasn't that bad.
#66
on
Originally Posted by Scrub
You might want to think about that.
#70
on
....20b FD 4-sale 0 miles $27K ...price drops $1k every so often...could use some wider wheels lol
http://www.rotaryextreme.com/20bforsale.html
#71
Sleeper but still slow
on
Originally Posted by montego
some people really enjoy projects dude. Besides there is an overwhelming cool factor in building your own 4 rotor rx-7.
#72
Derwin
on
Actually that sounds kind gay.
here is my car
As for the pricing, consider this a 720 hp Carbed V8 by AmericanSpeed intended for use in the Ultima GTR is 26,000 but it is drysump.
Personally I think if there is a place to put a 4 rotor it is in an Ultima GTR, there at least room is not a problem and your would be around 950kgs. Also you already would have the best suspension, cooling and all the rest.
here is my car
#74
on
Originally Posted by dgeesaman
That's a pretty big assumption.
Dave
Dave
#75
rebreaking things
on
Originally Posted by tphan
why dont just go buy a 2006 Z06...save bunch of headache.
Hey RT I noticed you live in Charlotte. What part?
#77
on
Didn't the Mazda LeMans 4 rotor produce 1000HP straight motor? Now if you had the money to do a 4 rotor in the first place...couldn't you just mimick their techniques? Especially since from what I've read is they achieved that 1k HP just by upping the revs to 11k instead of 9k which was far less HP. Of course I am talking about a super mechanic team that has endless amounts of money and R&D to be able to do this.
#78
bow leggin'
I think you need to research the 787 a bit more
Link
Link
#79
Derwin
on
What I think he hints or actually wanted to say if he could type in "english". Is that Lemans racers are always placed with restrictors on the engines that limit horsepower. So without limiations could a 26b produce 1000hp?
Also what do you mean they upped the redline to 11k instead of 9k. They just don't go into the Bosch or Motec or w/e ECU and change the redline and boom 300 hp more! This isn't gran turismo. I doubt anyone would want an engine to run Lemans that produces 1000 hp (Within current LMP1/2 regulations).
All this to say, in my beleif a 3 Rotor turbo or a 4 Rotor N/A is more than any street FD should ever dream of.
Alex
Alex
#80
1) i am a rotard, but honestly i have seen with my own two eyes a non built ls1 408 stroker w/ a big turbo and etc push over 1000hp/trq and run for a few years and also win the small block chevy with power adders class at hot rod's drag week last year, oh yea it weighs over 5000 lbs http://www.1320video.com/img/album01/67_G.jpg
so its not to take away from the lsx blocks, they are great and there are a lot of them making alot of hp
2) 23a's(12a) are shorter and lighter than a 20b, and i would love to make one some day
3) 4 rotors just sound SIIIIICK
4) screw 4 rotors, its about the 6 rotor!!!
http://www.hurleyrotary.com/hme13b.aspx
