Rotary Car Performance General Rotary Car and Engine modification discussions.
New Drag Times Thread
Old Jan 24, 2003 | 10:59 AM
  #101
Bigreddawg's Avatar
Originally posted by vosko
i think ernie ran 11.7 on stock engine too maybe ?
Ernie had a port job done well before that.
Old Jan 24, 2003 | 11:39 AM
  #102
vosko's Avatar
Just Call Me Terminator!
well boostn7 is the man like i said
Old Jan 27, 2003 | 07:28 PM
  #103
tcb100's Avatar
DinoDude
Ernie & Boostn7 both had stock motors for these time as did Kevin Wyum. Wyum had full non-sequential & upgraded twins of some sort.
Vosko is right: Boostn7 is the man in street & now with 400 HP he will probably go to the top of the list. I think Wyum's mark has been there since 1995 or something.
Old Jan 28, 2003 | 06:47 AM
  #104
Bigreddawg's Avatar
Ernie had a port job in his mod list well before he ran 11's or even before he ran low 12's.
Old Jan 28, 2003 | 07:44 AM
  #105
tcb100's Avatar
DinoDude
Ernie had so many motors its hard to keep track but somewhere on this forum he stated that his 11.7 was done on a "stock motor". I assume that means non-ported, no?
I suppose we could just ask him. In any event, Boostn7 is the clear winner for stock motor-stock turbos.
Old Jan 28, 2003 | 09:37 AM
  #106
vosko's Avatar
just wait till boostn7 runs in this nice cold weather
Old Jan 30, 2003 | 03:54 PM
  #107
93R1
RT .884
60' 2.154
330' 5.626
1/8 8.429
MPH 90.05
1000' 10.814
1/4 12.835
MPH 115.07
original stock block, stock sec twins, dp, cat back, half clogged stock cat (can smell the rotton eggs), pms, fmic,
heavy *** 17" rims on kumho street tires
Old Feb 5, 2003 | 05:59 PM
  #108
streetdreamzny's Avatar
60 - 1.822
330 - 5.272
1/8 - 8.029
mph - 87.98
990 - 10.345
1/4 - 12.378
mph - 115.65
stock engine,turbos + cat
Old Feb 8, 2003 | 01:15 PM
  #109
vosko's Avatar
very nice nof ! congrats. your getting into roll bar territory!
Old Feb 10, 2003 | 07:33 AM
  #110
matty's Avatar
Originally posted by streetdreamzny
60 - 1.822
330 - 5.272
1/8 - 8.029
mph - 87.98
990 - 10.345
1/4 - 12.378
mph - 115.65
damn you dropped 1.5 sec off your time since i seen you run. What did you do to the car?
Old Feb 10, 2003 | 04:30 PM
  #111
vosko's Avatar
nof learned how to drive
Old Mar 8, 2003 | 02:05 AM
  #112
red 7's Avatar
OK guys my first time back to the strip ,1/8 mile(sucks), in a year and a half got new mods and ET streets my previous best was 8.5 this time was:
reac. .243
60ft 1.745
330ft 5.038
1/8mi 7.789
mph 89.63
I launched at 6800rpm good burnout too (fun)
1st gear boost .9-.75 kg/cm2 (12.8-10.6 psi) ?????
2nd gear boost .8-.85 kg/cm2 (11.3-12psi) better control
3rd gear boost .75-.82kg/cm2 (10.6-11.7psi) to low
datalogit is awesome
this was my third run and i was turning the boost up every run it was very damp and misty probly 100% humidity but air temp was about 60F and i would of liked to run at least 14-15lbs of boost but my mail in maps(SR) are very conservative timing and rich fuel need tuning on dyno W/wideband
I think i can get a 7.5 from my setup:
airnx intake
stock turbos w/turbine trimmed and wastegate enlarged
permanent non-seq
greddy front mount & elbow type=s blowoff
2nd butterflies out and gasket matched UIM & LIM
1300 secondaries 550prim
streetported motor
hks downpipe, straight through midpipe, N1 dual catback
fuelpump avcr power fc koyo delete ast kaaz diff 4.33 short shift cusco catch can
i mostly autoX just drag to see how fast my car is
autoX mods:
apexi t-max struts ground control coilovers
all bushings in rear pettit launch kit
M2 trailing arms, toe links
swaybars tri-point in front and suspension in rear??
racing beat swaybar reinforcement, front strut bar cusco
kumHO victoracers 245/45-16
looks feed type2 replica
mazdaspeed replica hood
one last ? what do you think my 1/4 mile time would be?
by the looks of it problly 12 huh
oh yeah what kind of boost are you guys running the stock motor/turbo's to get so fast(boostn7) and shift points im shiftin at 8000 i think ive got a few tenths w/more boost
thanks, Rodney
Old Mar 11, 2003 | 05:28 PM
  #113
red7 - i think you would be in the 11's your 1/8 et and trap speed are both better than mine and i ran 12.3, look at my post about 2 above yours
matty- i don't really remeber what i did to my car since the last time i saw you but it was mostly improving driving like vosko said
Old Apr 3, 2003 | 09:46 AM
  #114
dvcn's Avatar
non-ported NA in the 13's
85 GSL, non ported 86 6 port 13B
Racing Beat Dellorto
Racing Beat exhaust
Racing Beat flywheel
Racing Beat torque brace
Racing Beat pulleys
MSD
4.88
Nitto 555R 205/55-14
weight w/ driver (IHRA track scale): 2420lbs
60' 1.9711
330' 5.7324
1/8 ET 8.9050
1/8 MPH 77.43
1000' ET 11.6451
1/4 ET 13.9657
1/4 MPH 97.12
Old Apr 3, 2003 | 12:28 PM
  #115
David88vert's Avatar
r71's daddy
So you're doing about 210 hp at the flywheel then?
Old Apr 3, 2003 | 12:47 PM
  #116
dvcn's Avatar
David- Long time no hear!
Yes, the calculators show 200-210hp at the flywheel.
Forgot to mention that this is car is set up for autocross.
Old Apr 4, 2003 | 08:41 PM
  #117
r71's daddy
I've been out of the loop for a while. Haven't really done anything to the car. Need to get back on it.
Old Apr 7, 2003 | 12:09 AM
  #118
t-von's Avatar
Rotor Head Extreme
My very first time ever at the track!
4 runs........
reac. 1.09
60' 2.666
330' 6.84
1/8 et 10.04
1/8 mph 77.58
1000' et 12.74
1/4 et 15.02
1/4 mph 99.31
reac. .99
60' 2.56
330' 6.71
1/8 et 9.90
1/8 mph 77.37
1000' et 12.60
1/4 et 14.87
1/4 mph 99.35
reac. 1.20
60' 2.72
330' 6.88
1/8 et 10.05
1/8 mph 77.84
1000' et 12.73
1/4 et 15.02
1/4 mph 98.55
reac. 1.27
60' 2.32
330' 6.30
1/8 et 9.43
1/8 mph 78.93
1000' et 12.08
1/4 et 14.34
1/4 mph 99.91
Sorry guys if I brought shame to the Fd. My 3rd run I lost to a Ford Lightning(1/4 et 14.26). Damn!!!!! I tried to launch at differant rpm's but could'nt stop all the wheel hop. Also all 4 of these runs were run in a span of 25 minuets. Not good for the stock intercooler. Anyways the next day I found out that I had some problems. I found out that my rear tires had 45psi. Thats way to much! Then the ghetto mod to my stock air box malfunctioned(ooops). This caused a partial blockage of air into the air box. While I was fixing the air box, I decided to extend the front scoop of the intercooler so it could pull more air while driving. All problems now fixed, I lowered the tire pressure to 14psi, went to my favorite issolated stretch of road and did some launches from 3k-4k rpms. WOW what a differance. The tires really hook up now. I cant wait till next weekend.
Old Apr 7, 2003 | 12:13 AM
  #119
t-von's Avatar
Rotor Head Extreme
Old Apr 13, 2003 | 08:57 PM
  #120
r_ed_line53's Avatar
Cool
This is my best on Drag Radials, Stock injectors, stock block, Apex fmic, Apex intake, dp, mp, Apeix N1 duals, Cosmo Fuel pump, Apex PFC & Controller, Stock suspension @ 13 lbs of boost;
RT .662
60' 1.781
330' 5.016
660' 7.738 @ 92.120 mph
1000' 10.078
1320' 12.076 @ 113.972 mph
Best on Mickey Thompson Slicks was an 11.792 @ 115.867 mph @ 15lbs of boost w/ 1.5 60' also same set up as above just different tires and boost level. No more runs after due to lack of roll cage.
great times out there...
see ya,
car 53
Old Apr 30, 2003 | 11:02 PM
  #121
fastrx7man's Avatar
Looking for 10's
Finally hit the 12's. My best pass tonight was a 12.5328 at 109.17 with a 1.8337 60'.
Old May 2, 2003 | 09:43 PM
  #122
tcb100's Avatar
DinoDude
Still no 11's. Warmish tonight, 75-78 degrees.
60' - 1.722
330-5.106
1/8-7.905
MPH @1/8 - 89.88
1000-10.251
1/4 - 12.237
MPH-114.57
Old May 20, 2003 | 10:09 PM
  #123
87GTR's Avatar
60' - 1.745
330-4.871
1/8-7.525
MPH @1/8 - 94.17
1000-9.770
1/4 - 11.691
MPH-115.35
60' - 1.618
330-4.897
1/8-7.551
MPH @1/8 - 92.31
1000-9.801
1/4 - 11.715
MPH-116.80
Nopi at Ennis Texas
Old May 24, 2003 | 07:58 PM
  #124
Resource's Avatar
New best.....running 14 psi.........traction blah!
60 foot 2.2
1/8 mile 95mph
1/4 mile 12.3
1/4 mile mph 119
Old Jun 26, 2003 | 02:16 AM
  #125
racer rx's Avatar
Elevation Above Sea Level: 2372 ft.
60 ft. 1.68
330ft. 5.022
1/8 7.79
1/4 12.15 @ 113.90 MPH
N-tech intake/ M2 Large IC/ Crane hi6/ Downpipe/ mid-pipe w. Borla/ Blitz catback/ Act pressure plate/eibach/ pettit delrin bushings/ 4.3 gears/M & H Racemaster drag radials/Mazdaspeed shifter.
Now added: Street ported w. 3mms/ Kazz LSD/ Koni shocks/Blitz SBC-ID boost contr./ and MT ET streets... can't wait til the next event.
j.
