Weld Drag Lite Fitment 2nd Gen
Old Mar 26, 2012 | 06:19 PM
JCurry's Avatar
Shpee
Hello, ive been searching but i havnt found any good info on people running weld drag lites on a fc. Im looking to buy some and need to know what backspacing and stuff i need for a 89 TII. I know i want 15" and it needs to be a 5 by 4.5 lug pattern but I dont know much more than that. Any info is appreciated
thanx
Old Mar 29, 2012 | 12:45 PM
JCurry's Avatar
Shpee
Can someone direct me to the proper backspacing and wheel and tire width i need? i need to buy a set of racing wheels and drag radials but dont know the size i need
Old Mar 29, 2012 | 03:09 PM
John631's Avatar
you should be looking at a 15x8 wheel with about +25 offset or 5.5 inch backspace, with that you can run a 27-10-15 full slick or about 255/60/15(not sure on sidewall) et street.
Old Mar 29, 2012 | 04:51 PM
JCurry's Avatar
Shpee
will the 5.5in backspacing put me about flush with the fenderwell? or do i have other options as far as backspacing?
Old Mar 29, 2012 | 06:33 PM
John631's Avatar
it should mount pretty flush, but if you go with to wide of a tire you run the chance of hitting the rear trailing arm and probably sticking out of the wheel well at the same time... you cant run too wide of a tire on the stock fc rear end.
Old Mar 31, 2012 | 01:51 PM
JCurry's Avatar
Shpee
ok cool, i think ill get the 5.5in backspacing wheels then
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
