What is broken?
Old Jul 24, 2002 | 01:43 AM
Ryde _Or_Die's Avatar
What is broken?
Alright what is the thing that has a tube coming from it going to the back left side of the i/c? It is also on the left side of the i/c. Has some other small tubes going other places. I really need a pic to describe it. The nipple is broken off in the tube so I need to know what part to order. Thanks.
Old Jul 24, 2002 | 02:06 AM
BoostedRotors's Avatar
I HATE sleepy eyes
what is it mounted on?
where do the hoses go?
vacuum hoses?
coolant hoses?
Old Jul 24, 2002 | 11:45 AM
Looks like vacuum hoses. It is just to the left of the i/c. Hmm, does anyone have a pic of the engine bay?
Old Jul 24, 2002 | 11:50 AM
DCmina's Avatar
here's Rx-7Addict's RX-7 engine
Old Jul 24, 2002 | 12:02 PM
HAILERS's Avatar
HAILERS
There is the air supply valve on the backside of the intake that has one black hose going from it to the rear of the intercooler. That connection is on the right/rear of the intercooler. Then on the right side there is a slightly larger black hose that goes to the intercooler from the air bypass solenoid. The only other hose are the large inlet and outlet hose on the intercooler.
The air supply valve on a series four supplies extra air during movement of the power steering. See the free download of the factory service manual at http://www.fc3s.org That valve has an electrical connetor on it.
Still doing wild *** guessing here. On the left side of the throttle body there is a water thermo valve that should have a hose going from it to the bottom nipple of the four nipples that sit one above the other on the throttle body. That water thermo valve should have one other nipple going to the front left side of the throttle body to a diaphram there.
Old Jul 24, 2002 | 12:20 PM
Alright, in that pic:
The tube is the farthest back, towards the windshield. It goes to something that is attached to the top of the intake manifold.
Old Jul 24, 2002 | 12:22 PM
Alright, see the hose going in the left side of the i/c? Well look at the hose clamp holding that hose on. Now go straight up, and theres some gray thing that has 2 tubes going into it.
Old Jul 24, 2002 | 02:37 PM
Josepi's Avatar
Despise Enmity
Is that your motor in the red car? If so get the throttle cable away from the alt pulley!!
Old Jul 24, 2002 | 05:11 PM
Hey man lets stay on the topic Whats the thing that has a small hose coming from the rear left side of the intercooler.
Old Jul 24, 2002 | 05:34 PM
Can someone make a pic smaller?
Old Jul 24, 2002 | 05:48 PM
HAILERS's Avatar
HAILERS
I see on the right hand side of the engine the intercooler inlet hose. I see the clamp on the hose. Just above the hose in the picture I see the grey object, sometimes called the aws on 89 and up cars but is really the AIR BYPASS SOLENOID. Should have an electrical plug on it. On a 87/88 car it is used for the 15second warm up period on a cold engine. It with the bac give you a fast idle of 3000 rpm for 17 seconds. If this AIR BYPASS SOLENOID is disabled, the cold start will only be approx 2300 on start up of a cold engine.
I see no hose going into the left side of the intercooler.
Old Jul 24, 2002 | 05:55 PM
HAILERS's Avatar
HAILERS
The bottom line is that if you were to plug the hose or tube on the intercooler, and disconnect the plug on the air bypass solenoid, you will never ever miss it. And neither will the engine.
Old Jul 25, 2002 | 08:42 AM
Ok I put arrows to what I am talking about.
Old Jul 25, 2002 | 08:43 AM
Old Jul 25, 2002 | 11:13 AM
hypntyz7's Avatar
You dont need that **** anyway...plug the holes and go on wth your day
Old Jul 25, 2002 | 11:53 AM
I HATE sleepy eyes
Agreed, I 86'd mine as well.
Old Jul 25, 2002 | 03:47 PM
Since there is a hose going in and a hose coming out can I just replace it with a longer hose? Does anyone know what it is anyways? Thanks.
Old Jul 25, 2002 | 04:08 PM
HAILERS's Avatar
HAILERS
What part of AIR BYPASS SOLENOID VALVE do you not understand? And its on the right side of the engine, not the left. No you can't put a longer hose in its place. The valve is a on/off solenoid for only 17 seconds during cold startup. You don't want a continuous flow of air all the time the engine is running. Cap the intercooler. Pull the plug off the valve. Buy another at the wreck yard. The n/a one is similar if not the same. Don't give more than ten bucks.
Old Jul 25, 2002 | 06:09 PM
Sorry man, lol. You said I didn't need it so I thought I could bypass it. Oh and I am talking about on the left side while looking at the car from the front.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
