possible suspension change suggestions?
im getting ready to purchase some wider wheels/tires. my current setup is:
17x7 +45 rims with 225/45/17 tires
koni yellow shocks (on the highest perch)
eibach lowering spring
my issue is that i think the car is too low. ive already ripped out both fender liners and my wheels rub the fender when making a turn and hit a bump. so being i want to get wider rims and tires i think it would be best to lift the car up 3/4"-1"
looking to pick up enkei rpf1's 17x8.5 front and 17x9.5 or 17x10 in the back. also the nitto tires i want are available in a 275/40 rear and 235/40 front series tire which would make the car even lower (oil pan is like 3" off the ground as it is)
what spring/shock setup would you suggest? dont wanna go to a stock height, but dont wanna keep tearing up my front fenders/tires.
thanks!
thanks!
I've had similiar problems with 235/45-17's, running H&R sports on Konis, in extreme loading situations (auto-x, some driveway curbs when turning). So, the H&R's may not be the best for you either.
The Ground Control coilover kit may bet a good solution, one which I'm considering for it's adjustability, are relatively low cost (about $600 new). These will work with the existing Koni's.
Nice choice on wheel and tire sizes. You may want to consider a 245/40 up front.
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
