Solo II Race Prep
Old Jul 23, 2002 | 05:50 PM
Newbie
Question Solo II Race Prep
I am planning on autocrossing my 82 rx7, in a few weeks, and I am looking for any quick (read inexpensive) tips to help me or my car do better. This is my first time, so any information about how to go about this would be great. The only performance mods i've done are a K&N filter. Thank you for any assistance.
thanks
Old Jul 23, 2002 | 07:06 PM
Silkworm's Avatar
Has been.. hangin' around
None. Don't mess with it. Go auto-x. Stock tires, stock brakes, stock everything. Just get a helmet, and go do it. Seat time is far more important than equipment. Trust me.
Dooooooooooooo it.
PaulC
Old Jul 23, 2002 | 07:39 PM
Kill No Cone's Avatar
PaulC is right,
nothing makes you faster than learning to drive faster.
Old Jul 23, 2002 | 08:57 PM
If your car is still stock you'll be running in E-Stock. Pick up a rule book and read through it thouroughly. Your best bet is to ask quesitions at the event, specifiacally to those whom are in your class.
And yes seat time is most important
Mario
Old Jul 24, 2002 | 08:49 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
I agree with teh rest of them. the 1st time out all the little things you do with you car aren't going to make a damn bit of differencem it's all about driver.
As long as you improve your times each run.. And I figure if you don't hit at least a couple cones then you weren't trying nearly hard enough!
But if you do want a couple hints, to the chalk the tires to find tire pressure, and pay attention to how much gas you have... Such a light car will handle very differently with a full tank vs 1/4 tank.
Old Jul 24, 2002 | 09:39 AM
redrotorR1's Avatar
LS6 Convert
No mods ... maybe only a new set of tires if your current set is wearing thin on tread. Go run novice class and ride with some of the fast guys during their runs. You can learn a lot just from riding.
Here's some tips I picked up from Andy Hollis, a Solo II national champ and Evolution school driving instructor:
1) Position first, then speed. Positioning the car perfectly is more important than trying to attain the highest potential speed. For example, you will drop more time by correctly positioning the car nearer to slalom cones than you will by adding 1 or 2 MPH in speed. Same with sweepers (tight line). Same with 90-degree turns (use all of the track). Also, position is a prerequisite for speed. If you are not in the correct
place, you will not be able go faster. Or at least not for very long!
2) Turn earlier...and less. To go faster, the arc you are running must be bigger. A bigger arc requires less steering. To make a bigger arc that
is centered in the same place, the arc must start sooner (turn earlier).
3) Brake earlier...and less. Waiting until the last possible second approaching a turn and then dropping anchor at precisely the correct place so that the desired entry speed is reached exactly as you come to the turn-in point is quite difficult to execute consistently. Especially when you consider that you get no practice runs on the course, and the surface changes on every run, and you aren't likely to be in exactly the same position with the same approach speed on every run, etc. Better to start braking a little earlier to give some margin of error. And by braking less you can either add or subtract braking effort as you close in on the
turn-in point. This will make you consistent and smooth.
4) Lift early instead of braking later. Continuing with the philosophy of #3, when you need to reduce speed only a moderate amount, try an early lift of the throttle instead of a later push of the brake. This is less upsetting to the car, is easier to do and thus more consistent, and allows for more precise placement entering the maneuver (remember #1 above).
5) Easier to add speed in a turn than to get rid of it. If you are under the limit, a slight push of the right foot will get you more speed with no additional side effects. On the other hand, if you are too fast and the tires have begun slipping, you can only reduce throttle and wait until the tires turn enough of that excess energy into smoke and heat. Don't use your tires as brakes!
6) Use your right foot to modulate car position in constant radius turns, not the steering wheel. In a steady state turn, once you have established the correct steering input to maintain that arc, lifting the throttle slightly will let the car tuck in closer to the inside cones. Conversely, slightly increasing the throttle will push the car out a bit farther to avoid inside cones. It is much easier to make small corrections in
position with slight variations in the tires' slip angle (that's what you are doing with the throttle) than with the steering wheel.
7) Unwind the wheel, then add power. If the car is using all of the tire's tractive capacity to corner, there is none left for additional
acceleration. At corner exit, as you unwind the wheel, you make some available. If you do not unwind the wheel, the tire will start to slide and the car will push out (see #6 above).
8) Attack the back. For slaloms (also applicable to most offsets), getting close to the cones is critical for quick times (see #1). To get close, we must move the car less, which means bigger arcs. Bigger arcs come from less steering and require earlier turning (see #2). Now for the fun part...
When you go by a slalom cone and start turning the steering wheel back the other way, when does the car start to actually change direction? Answer: When the wheel crosses the center point (Not when you first start turning back!) How long does that take? If you are smooth, it takes .25 - .5 seconds. Now, how long is a typical person's reaction time? Answer: about .5 seconds. Finally, how long does it take to go between slalom cones? Answer: Typically on the order of 1 second. Given all of that, your brain must make the decision to begin turning the steering wheel back the other way just *before* you go by the previous cone!!
Since this is a mental issue, a good visualization technique to get used to this is to think about trying to run over the back side of each slalom
cone with the inside rear tire of the car. To hit it with the rear tire (and not the front), the car must be arcing well before the cone and the arc must be shallow. Attack the back!
9) Hands follow the eyes, car follows the hands. 'Nuf said.
10) Scan ahead, don't stare. Keep the eyes moving. Looking ahead does not mean staring ahead. Your eyes must be constantly moving forward and back, and sometimes left and right. Glance forward, glance back. Your brain can only operate on the information you give it.
Bonus Tip: Don't forget the stuff in between the marked maneuvers! Too often we think of a course as series of discrete maneuvers. There is typically more to be gained or lost in the areas that are in between. Pay special attention the places where there are no cones.
When you first start, auto-x is 90% driver skill. It's only when you get really good that the car starts becoming an issue.
Old Aug 1, 2002 | 04:54 PM
Siraniko's Avatar
RX for fun
where can i get info on auto-x. im in socal.
Old Aug 1, 2002 | 05:16 PM
autocrosser's Avatar
www.solo2.com
Old Aug 1, 2002 | 07:23 PM
Adsy01's Avatar
ACBron Motorsport
redrotorR1, thanks for that great reply!
Old Aug 2, 2002 | 07:50 AM
Rated R1's Avatar
Oji San
Yeah good tips redrotorR1. Now, if I can just remember all that when my adrenaline is pumping. Check out this link I found it to be useful reading before my 1st autocross.
http://www.tirerack.com/features/solo2/handbook.htm
Old Aug 2, 2002 | 10:01 AM
finky's Avatar
Ask the fast guys if you can ride with them. Most people are cool and will let you ride. You see lines you would not have run yourself.
Old Aug 2, 2002 | 01:33 PM
redrotorR1's Avatar
LS6 Convert
I just got finished with the Phase I Evolution Driving school (auto-x school) this past weekend. Andy Hollis was actually one of my instructors ... and Tommy Saunders (9-time Solo II champ). The one REALLY important thing I can say is that smoothness is the key. The smoother you are through a course, the faster you can run it. You may be able to get between gates faster on rough lines, but you'll lose that time and more just trying to settle yourself for the next transition. Learn the smoothest lines first, then add speed. It works like a charm.
Sandro
3rd Gen General Discussion
24
Dec 30, 2017 03:35 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
