Go Back   RX7Club.com > Tech and Performance > Engine Management Forum
Old 06-13-01, 09:56 AM   #1
Turbo7
Rotorite
Send a message via ICQ to Turbo7
Tuning for Fuel Economy
I'd like to know if the Microtech MT-8 or Wolf3D have the tuning resolution to obtain Air/Fuel ratios of 14-15:1 at idle and under low rpm "cruise" driving?
I read on another forum that the they aren't capable of reliably doing this.
Which of the 2 computers is better? I currently know of 1 of each available to me that are second hand and reasonably affordable. Please don't start a debate about other ECUs unless you can find me one for cheap.
Daniel
Turbo7 is offline   Reply With Quote
Old 06-13-01, 11:36 AM   #2
BOOSTD 7
Persona non grata
BOOSTD 7's Avatar
Send a message via ICQ to BOOSTD 7 Send a message via AIM to BOOSTD 7
I have a Wolf 3D. I drove my car with it from Spokane Washington to St Louis MO last year. I started out getting about 8-9 mpg, and after working on it for awhile I got it up into the 22-24 mpg range. The tradeoff was that it would go lean under part throttle so you wouldn't want to get all over it. But it was very smooth with that map.
The Wolf also has a closed loop mode for cars with catalytic converters. I never used this, but it might do the trick also. It basically adjusts itself to stay close to stoich. Again, not good if you want to run lots of boost, but fine for highway cruising.
BOOSTD 7 is offline   Reply With Quote
Old 06-13-01, 11:51 AM   #3
Turbo7
Rotorite
Sorry if this sounds stupid, but what do you mean by "so you wouldn't want to get all over it"
Also, are you happy with the performance of the Wolf?
thanks
Daniel
Old 06-13-01, 12:42 PM   #4
Cosmo Donk
Queer
Cosmo Donk's Avatar
Send a message via ICQ to Cosmo Donk Send a message via AIM to Cosmo Donk
I have also tuned for economy because I had no boost for a while.
What Ryan, Boostd, may be speaking of is that when you are very lean in the crusing ranges when you hammer on it, any time you are in that RPM range at that vacuum it will be lean but since it is low in vacuum it should be fine.
Pretty much, you can make those EMS's make the car run great under all conditions but personally I would go with the Wolf. You can get as good if not better economy than the stock pile of junk with a good EMS.
With some tewaking and some time, you will have a great running car with good economy.
$.02
AOL = sniffigitawhump
ICQ is up at the top.
E-mail me moreiraeric@usa.net
My car
This sig has been brought to you by Jef Card.
Cosmo Donk is offline   Reply With Quote
