Go Back   RX7Club.com > Tech and Performance > Engine Management Forum
Old 05-20-01, 11:33 PM   #1
Drag Rx-7
Passenger
Posts: n/a
Haltech Single Turbo Maps!!
I have a race ported 13bt and I need to get some maps for a single turbo with about 30 psi. I will be using the T-76 turbo. My fuel system is 2 720s and 4 1600s. Where in gods name do I find them?
Old 05-21-01, 04:23 AM   #2
HWO
inteligent extratarestril
HWO's Avatar
Send a message via ICQ to HWO
reckon you have enough fuel flow?
my quick calculation show that set up is enough fuel for around 1200HP
HWO is offline   Reply With Quote
Old 05-21-01, 06:34 AM   #3
MAZMAN
seems like you have enough money to go and get some1 to tune it for you and raise the boost to your requirements,insted of hoping some1 has a 30psi boost map.
MAZMAN is offline   Reply With Quote
Old 05-21-01, 06:39 AM   #4
MikeL
Grandpa Smack
MikeL's Avatar
Well, with all of that potential fuel flow, your injectors will run at a low duty cycle and therefore propably last a long time.
There are some maps here: http://www.hitman.hm/maps.htm . Nothing with the injector combnination that you have though. Maybe you could run without the extra two 1600's to start with.
Here's my map. I run 2 550's and 2 1600's. http://brfoundation.com/RX-7/dyno.htm .
There is also a 376 rwhp dyno run datalog. You MUST load my map to properly see the datalog.
The map will at least get your car started.
Mike
MikeL is offline   Reply With Quote
Old 05-23-01, 01:59 AM   #5
HWO
HWO's Avatar
basically you'd need to cut Mike's Secondary injector duty in half to get an indication of what you will run
Old 05-23-01, 08:31 PM   #6
gmonsen
The Ancient One
gmonsen's Avatar
hehehe...four 1600's? that's the most potential fuel flow i've ever seen on a rotary. 7840cc/min? got milk? plan on running 20% duty cycle? i doubt the T76 is going to e able to flow enough air to use much of those 1600's. i think you've got 2 too many. -gordon
gmonsen is offline   Reply With Quote
Old 05-23-01, 09:20 PM   #7
crispeed
'Tuna'
crispeed's Avatar
Send a message via AIM to crispeed
Hey Greg!
If you move down here for a week or two we could hook everything up and get it running like a bat out of hell! HE HE HE
crispeed
87TII
9.67@141mph
crispeed is offline   Reply With Quote
Old 05-23-01, 09:24 PM   #8
crispeed
'Tuna'
crispeed's Avatar
YEH!
Greg wanted to make sure he had eneough fuel for the 13b and 20b together.
Hey Gordon you'll be surprise how much air the T-76 can flow and do max out the 1600's just above 600RWHP at around 11.2 to 1 A/F.
crispeed
87TII
9.67@141mph
Old 06-02-01, 03:11 PM   #9
Greg
Greg's Avatar
Send a message via ICQ to Greg Send a message via AIM to Greg
I also plan on using a big shot of NOS (150 - 200) the 2nd 1/8th mile. I also want a shitload of boost (30+)
Greg is offline   Reply With Quote
