15x8 offset
Old Feb 7, 2012 | 05:27 AM
slidewithstyle's Avatar
15x8 offset
Ok guys I've searched and couldnt find anything. (I thought it would have been in the archive) Anyway I'm wanting to use Enkei 92s like these.
Size:  39.5 KB I want to run the 8 wide front and rear what offset do I need for them to be flush with zg flares? should I go wider in the rear to match the zgs.?
Thanks
-Austin
Old Feb 7, 2012 | 07:34 AM
Siraniko's Avatar
RX for fun
4.5" backspace
Old Feb 7, 2012 | 08:43 AM
ih8dsm's Avatar
Zero offset on the front is pretty much flush back needs about - 5 to sit flush.
Old Feb 7, 2012 | 08:53 AM
lx_machado's Avatar
Here is 15x8 zero offset
Old Feb 7, 2012 | 01:04 PM
82FanTC's Avatar
Work in Progress
You must have a pretty wide tire on those wheels because a 15x8 zero offset/4.5 backspacing does not set that far outside the fender. The wheels with sit almost flush, just a touch wider, with the fender and some 205x50s fit quite nicely.
Old Feb 8, 2012 | 08:53 AM
Siraniko's Avatar
RX for fun
0 offset is 4"? I want to see pix of the inner tires n wheel well
Old Feb 8, 2012 | 10:14 AM
Rotarx7's Avatar
hoycee$$$$$
i have the ZG flares on my car but im running 16x8.5s with a -6 offset. They sit pretty flush but on 205s. Running a 0 offset would allow you to run a wider tire. 0 offset with 225s should fit perfect. Im planning on running wider flares soon just so I can run something wider than a 205 without rubbing.
check these out:
http://www.zforceproductions.com/ind...d=15&Itemid=60
Old Feb 8, 2012 | 11:06 AM
Kentetsu's Avatar
Yep, that looks about identical to my 13x8 Revolutions (4" BS) and my 13x8 Diamond Racing (4" BS).
Attached Thumbnails 15x8 offset-262134_201145899938034_159960587389899_630746_3343594_n.jpg   15x8 offset-picture-173.jpg
Old Feb 9, 2012 | 09:46 PM
mustanghammer's Avatar
A zero offset 8" wide wheel generally has 4.5" of back spacing in my experience. Put a tape measure on a 8" wheel and you will see that they are pretty close to 9" wide from outer edge to outer edge.
From the pictures it looks like a +15mm or +25mm would be a better choice. Also some camber on the front would pull the tire in better.
Thanks for posting. I will be running 15x8 wheels on my race car and I have been trying to figure out the proper off-set. I will be running a 225/45 tire.
Old Feb 9, 2012 | 10:57 PM
snowbreaker's Avatar
now 17 with 2 cars **)
thats pretty badass just saying
Old Feb 10, 2012 | 03:22 PM
Thanks guys for the response mhat is the widest tire possible in the rear with ZG flares?
Old Feb 10, 2012 | 03:41 PM
j9fd3s's Avatar
Community Builder
if you're not doing at least 245's you're wasting your time.... 225/45/15's fit the stock fenders with no rolling....
Old Feb 10, 2012 | 06:41 PM
Thanks I need as much rubber on the back as I can get.
Old Feb 11, 2012 | 12:32 AM
orion84gsl's Avatar
My 7 is my girlfriend.
I had a 15x8 +20 Rota RB on the rear and it sat JUST inside the fender. Rubbed a tad but nothing to sweat over. The front was another story. Using 15mm spacers with the same size wheel the tire poked outside the fender a bit and was able to rub the set screw on the coilover sleeve perch if it was clocked the right (wrong?) way. It's tight up front. A 7.5 inch +14 (which I have now) fits damn near perfectly. A slightly narrower tire will keep it from tearing up my fenders any more than they have been.
PS, I have ZG rear flares that I bought but won't be using, if your interested.
Old Feb 11, 2012 | 06:26 PM
PM sent
Old Feb 11, 2012 | 07:31 PM
lx_machado's Avatar
The tire size on that car is 205/50/15
I would have kept the wheels it they were flush
Old Feb 11, 2012 | 09:36 PM
Siraniko's Avatar
RX for fun
15x8, 4.75 backspace but have been better if I were to run 225-45 series instead of 205-50
same rims in my tender blue RX-3 with VW Cabriolet fender flares
doritoloco
Sep 17, 2015 03:51 PM
