A/c not charging can it be this? Pic inside
Old Feb 3, 2012 | 08:55 AM
Touring's Avatar
I posted a issue about this before about the a/c not tacking in the freon and wanted to know if it could be this that is bad? It's the cylinder part and right where the line goes in its drenched with oil at the fitting. It seems like it is not working properly. Can this be it? What is it.
Old Feb 3, 2012 | 09:45 AM
83Limited's Avatar
Why am I doing this?
Thats the receiver/drier....if its leaking, it definately would explain why you arent able to get the system to charge. The oil you are seeing could be compressor oil (in the freon as a lube) residue thasts left after it leaks out. Best I remember it has an o ring seal at each line. That part will be available at an auto parts store for order, Id replace it, they arent too expensive. Think of it almost as a "filter" for your AC system....
Old Feb 3, 2012 | 11:03 AM
rwatson5651's Avatar
79 w 13B4port
Yea, that should be replaced as a matter of course anytime you recharge the ac after its been out of service. It is a filter and it has a dessicant in it to remove moisture from the system. Another thing that needs to be replaced as a matter of course is the expansion valve mounted in the evaporator under the dash.
Old Feb 3, 2012 | 12:02 PM
Touring's Avatar
What ones the expansion valve look like?
Old Feb 3, 2012 | 02:47 PM
79 w 13B4port
generic pic, the one for your car may look slightly differrent.
Old Feb 3, 2012 | 03:01 PM
83Limited's Avatar
How hard is the expansion valve to get to on an RX7? I have never done one in a 7....but will have to when I redo the AC later this year....
Old Feb 3, 2012 | 03:07 PM
79 w 13B4port
Its not to bad, disconnect the two ac lines at the firewall, three bolts that mount the evaporator underneath the dash and the clamps that secures the duct to the fan and the heater. Remove the clips that hold the two halves of the evaporator cover and then the fittings that connect the valve.
Old Feb 3, 2012 | 04:25 PM
83Limited's Avatar
Sounds good, was scared the dash was gonna have to come out....glad it doesnt...thanks!
Old Feb 3, 2012 | 04:32 PM
clykins's Avatar
Silly question... Do you need to depressurize the system? How?
Old Feb 3, 2012 | 04:52 PM
79 w 13B4port
If you go by the rules you need to go to a shop and have it evacuated (to keep the refrigerant out of the atmosphere. )
Old Feb 3, 2012 | 06:54 PM
Touring's Avatar
ill pay someone 15$ to post a diy!!!
Old Feb 4, 2012 | 04:55 PM
Touring's Avatar
Do I have this on right?
Old Feb 5, 2012 | 07:49 AM
Touring's Avatar
that was the worst install ever.... took about a hour. extremely hard
Old Feb 6, 2012 | 05:45 AM
arran's Avatar
I think you have it the wrong way around. The gas enters the top of the condensor, out the bottom and then IN to the receiver dryer. You have the IN pointing away from the condensor
http://www.auto-repair-help.com/auto...e_receiver.php
Arran
Alpine
Microtech
Sep 5, 2015 09:42 AM
