Go Back   RX7Club.com > Tech and Performance > Engine Management Forum
Old 05-15-01, 08:35 PM   #1
Twin Rotor
Passenger
Posts: n/a
Cool Haltech Help???
Please help!! Can anybody tell me the operating frequency of a stock TII BAC and boost control valve?? I tried 30ms for the BAC and it was louder than the motor. Is this correct?? Thanks for any input.
1986 TII
hybrid turbo
j-spec series V motor Haltech E6K
720cc secondary injectors
Aftermarket exaust
1983 Mustang coupe
Cartech outlaw turbo kit
Haltech F3
paxton fuel system
1983 ford f-150
460ci big block
Old 05-19-01, 02:53 AM   #2
Styk33
Haltech E6K
Styk33's Avatar
Send a message via ICQ to Styk33 Send a message via AIM to Styk33 Send a message via Yahoo to Styk33
Arrow
Cosmo Donk should have this info. Why hasn't he posted here? If you have a good map in your car you should not need a BAC unless you are running an anti lag setup.
<A HREF="http://ricemobile.net/" TARGET=_blank> </A>
Jay
The Ricemobile
94 Base w/ never enough mods
87 Base w/ never enough miles
Styk33 is offline   Reply With Quote
Old 05-19-01, 04:55 AM   #3
MAZMAN
i think the manuel says 30ms for the boost solenoid,but was told to run 33ms.tried both but had also trouble with the solenoid,could not get boost.
whats a BAC...my mind has just gone blank,i cant figure out what that is
MAZMAN is offline   Reply With Quote
Old 05-21-01, 11:40 AM   #4
Cosmo Donk
Queer
Cosmo Donk's Avatar
Send a message via ICQ to Cosmo Donk Send a message via AIM to Cosmo Donk
I haven't posted because I do not run a BAC. MikeL on this board runs one I think but as Jay said, they really are not necessary unless you run large electrical drains or you want a high cold idle to smooth things out like the stock thermowax.
Cosmo Donk is offline   Reply With Quote
Old 05-21-01, 12:10 PM   #5
MikeL
Grandpa Smack
MikeL's Avatar
I do have one on the car. It is disabled on the PWM Options page.
The idle speed control is enabled on the output Options page. I have target rpm at 900. I have the physical idle screw set at 1000. The only time the BAC wakes up and makes noise is when I turn on the a/c. It drags rpm down to about 750 and then the BAC brings it up to 900.
I don't pretend to understand this. Maybe there's a better way to do it.
Mike
MikeL is offline   Reply With Quote
Old 05-21-01, 08:29 PM   #6
Twin Rotor
Passenger
Posts: n/a
Cool
The car runs better (more stable idle) with the BAC turned off. It's not that I need it but I wan't it to idle up with the a/c. I'll try to increase the hard idle so that the BAC only takes over when I turn on the a/c.
Thanks a million.
1986 TII
hybrid turbo
Aftermarket exaust
1983 Mustang coupe
Haltech F3
paxton fuel system
1983 ford f-150
460ci big block
Old 05-22-01, 11:45 PM   #7
Styk33
Haltech E6K
Styk33's Avatar
Mike, now that you explained how you have yours setup, it makes sense now. If you read the instructions manual (if you have it) you will see that is says to 'disable' the PWM option for BAC if you are using it for idle speed control. That way it uses the settings in the 'input/output' page.
This all from reading the manual. I use mine for the ALS since the only elecrical draw on my car is my stereo
Jay
