17x9 +35mm offset on FC rx7 stock body
Old Jan 23, 2012 | 09:27 PM
RRTEC's Avatar
Rotartist
Will this fit? if not what size spacer will I need? Thanks for the help, picking up the wheels wednesday if they are good to go.
thanks
Old Jan 23, 2012 | 10:24 PM
MaczPayne's Avatar
Mac Attack
a 10mm spacer would work perfectly, as long as you have coilovers
You'll need a roll and camber up front to tuck 255's in, and less if you're using narrower tires.
Old Feb 1, 2012 | 02:27 PM
eage8's Avatar
1308ccs of awesome
rear will be fine, you'll probably need a 10mm spacer up front, maybe 5mm depending on the tire and suspension
Old Feb 2, 2012 | 10:13 AM
FirstRotaryExp's Avatar
The Brap is Back
in case you were wondering, this is what a 17x9 +20 with a 255/45 nitto 555 tire looks like up front with utterly stock suspension (at full droop as the car 'is' off the ground)
I can barely fit a finger between the wheel and the spring perch. Personally i'll be on the look out for 20-30mm widebody front fenders to clear without having to resort to massive camber to fit... I like not blowing $600 because 1/2 the tire is threadbare.
