stripped nikki carb??
Old Jan 16, 2012 | 09:36 PM
viper7389's Avatar
i am really looking for a how to guide on stripping a factory nikki carb partly due to the fact that the original owner of the car pretty much screwed the original engine harness. i have seen pictures of the carb stripped but i am really just needing to know what i can remove and clean the carb up. i have the factory carb service manual i downloaded and i cant really determine the process of stripping it down and dont want to mess up the only carb i have i plan on a fresh rebuild for it before putting the new engine in my 7. i have an 85 gsl and i have, the carb and engine i beleive are from a 81 and i was hoping to utilize the factory rats nest but now i cant. any help would be greatly appreciated.
Old Jan 17, 2012 | 07:00 AM
CobraStngSVT's Avatar
Team SR
Remove the items highlighted in pink.
Old Jan 17, 2012 | 07:19 AM
Take-7's Avatar
car setter on firer
or download the how pdf in the "faqs" section. Believe it or not, there is a noob section.
Old Jan 17, 2012 | 08:30 AM
Team SR
lol or "search"... this only gets brought up about once a month or so..
Oh well. Good luck with the stripping.
Old Jan 17, 2012 | 09:46 AM
Take-7's Avatar
car setter on firer
The how to from vipernicus was a great walk through for me, all I had to do was strip it at my kitchen table with the laptop right there
Old Jan 17, 2012 | 10:01 AM
DivinDriver's Avatar
1st-Class Engine Janitor
You guys forgot the most important step... send all the left-over parts to me!!!
Old Jan 17, 2012 | 01:16 PM
viper7389's Avatar
Yeah none of the pics on the faq how towould show up. But the diagrams cobra are what I was looking for. The only question left is do I need to do any block off plates
Old Jan 17, 2012 | 01:18 PM
Take-7's Avatar
car setter on firer
Yes, you will need to block off the acv on the side, and the weird tube thing on the back
Old Jan 17, 2012 | 05:10 PM
...and the EGR, if you have one.
Old Jan 18, 2012 | 02:20 PM
snowbreaker's Avatar
now 17 with 2 cars **)
i have topic questions, what about the 4 little filters/screens throughout the carb? what happens if you remove them and dont put them in, pros and cons of having them?
Old Jan 18, 2012 | 02:53 PM
viper7389's Avatar
hey little of topic but snow breaker i have a great deal of family that live in grand rapids. and what wheels and off set are the wheels in your avatar, also thanks alot by the way for the guide cobrastng already tore the carb down and have started on the clean up. ordered rebuild kit waiting on it to ship then ill be ready to fire up my engine.
Old Jan 18, 2012 | 02:59 PM
Team SR
awesome, just don't lose the two check ***** and spacers in the accelerator pump system! Let me know if you need any more help.
p.s. you may also want to open up the accel. pump nozzle and bolt while you have it out.
Old Jan 18, 2012 | 04:41 PM
sorry its just an avatar, but i think the wheels are koni rewinds or something along those lines
cobrasting- since you do all the rebuilds, what about the 4 screens found throughout the carb?
Old Jan 18, 2012 | 07:11 PM
No real pro to removing them (so long as they are clean), con of removing them is that some crud can get by your fuel filter or originate in your lines. The screens stop said crud from getting into the carb, inside the tiny unreachable passages.
Old Jan 18, 2012 | 07:43 PM
Siraniko's Avatar
RX for fun
ditch it....you dont need that filterprovided that your tank is clean and there is a good filter before the pump. I never use them on old school NIkki and aftermarket carbs such as IDA, DCO/DCOE, dellorto and mikuni. Never had a problem
Old Jan 18, 2012 | 09:41 PM
viper7389's Avatar
once i drill out the jets and such what kind of power gain am i looking at??
Old Jan 18, 2012 | 09:58 PM
Siraniko's Avatar
RX for fun
Typically, go one size bigger from stock, go for a hard run, and if you feel that the engine still wants to pull, then drill again until it stop from pulling and go one size smaller. You do this one primaries first then secondaries. Its not easy to tune a nikki as the jets are not easily accessible and you will need a good supply of jets unless the carb has been reemed to accept holley jets. also learn how to read your spark plugs.
Old Jan 19, 2012 | 10:11 AM
Team SR
You're fine ditching the screens as long as you have a good fuel filter before the carb.
jdmbrendan
Oct 1, 2015 01:29 AM
