Drive Shaft removal
Old Jan 9, 2012 | 08:45 PM
Erifx's Avatar
Exclamation Drive Shaft removal
How do you remove the drive shaft on my 1985 12a manual? I got the bolts out now the thing well not come off Help?!?!?!?!
Old Jan 9, 2012 | 10:57 PM
FunK73's Avatar
Fighting Global Cooling
Hammer
Old Jan 10, 2012 | 12:07 AM
Erifx's Avatar
tried it well not move
Old Jan 10, 2012 | 12:20 AM
valley's Avatar
While I don't have an sa/fb I'm going to assume it's set up like most other rwd cars. Take a putty knife, craper, or something similar to the driveshaft to diff. flange. Set it at the seem and hammer it into it. Might want to lube it with some liquid wrench or similar first if you have it.
Old Jan 10, 2012 | 06:33 AM
DerrickS's Avatar
His name is spot
oooohhhh......
MN. Sorry...
Try a smaller cold chisel at the flange. Let the liquid wrench set in a while longer.
Old Jan 10, 2012 | 09:17 AM
EDSRX3's Avatar
Bigger hammer!
Old Jan 10, 2012 | 09:49 AM
Erifx's Avatar
I sorry to say a bigger hammer worked lol Now I got question how to I clean the bel houseing. What something that well make it easyer
Old Jan 10, 2012 | 10:20 AM
KansasCityREPU's Avatar
Out In the Barn
Brake cleaner and a rag works good to clean the inside of the bellhousing to remove grease/oil. If you want to clean the outside, a wire wheel works well.
Old Jan 10, 2012 | 10:49 AM
Erifx's Avatar
is here a gasket from the transmission to the engine?
Old Jan 10, 2012 | 11:29 AM
murben's Avatar
nope, no gasket between the engine and transmission.
Th0m4s
Feb 26, 2019 02:04 AM
turbo-minivan
69
Feb 4, 2016 12:29 AM
rx7jocke
Aug 15, 2015 03:36 PM
