Go Back   RX7Club.com > Tech and Performance > Engine Management Forum
Old 03-07-01, 10:00 PM   #1
Rotary93
Retired RX7 mechanic
Rotary93's Avatar
Send a message via AIM to Rotary93
Thumbs up PMC timing?
What do you guys have your timing set at when stock?
I have a PMC and need to know the stock timing.
Also You guys with PMCs, How the hell do you program this thing?
Anthony
Rotary93 is offline   Reply With Quote
Old 03-08-01, 03:35 PM   #2
VooDoo Child
Passenger
Posts: n/a
My timing for stock boost is set at 0 for all rpm points.
To Program, you first of all need to know what you want to do. eg. to make fuel adjustments. First of all, after you turn on the ignition press enter & a screen on the keypad should come up asking which data set you want to get into. Say you want to adjust data set 1, press 1 & then enter. Then the next screen asks what menu you want to get into. For fuel, that's menu 6, so press 6 & enter. Boost at 1psi screen comes up. You don't need to do any adjustments here, so press the button II for max boost screen, max boost at 2200rpm comes up. Continually pressing the II key goes thru the rpm points you can adjust-2200, 4000, 6000, 7800. Press the add or sub keys to add or subtract fuel. To save your changes after adjusting ea. rpm point, press enter then save/tog, screen comes up asking which data set you want to put the changes to. We,re adjusting #1, so press 1. That's it basically, for fuel. To make timing adjustments, you'd have pressed the III key instead of II above.
Hope this helps, I'll answer any more questions you have best as I can.
Chris
Old 03-08-01, 03:38 PM   #3
VooDoo Child
Passenger
Posts: n/a
Shit, I made a mistake. You'd press key #I to get out of the Boost at 1psi screen to get to Max Boost screen then press key#II to cycle thru the rpm points. Sorry!
Old 03-13-01, 12:42 PM   #4
Wade
I have some PMS faq's on my website at www.wvinter.net/~flanham/wlanham.
Hope this helps,
Wade
Wade is offline   Reply With Quote
