GSL-SE ground
Old Dec 21, 2011 | 06:44 PM
Cyris426's Avatar
GSL-SE ground
Hey guys, just a quick question, where is the GSL-SE EFI ground? As i understand it is underneath the upper intake manifold. I am looking to clean the ground and use dielectric grease. If it is under the upper intake manifold though, how do i run a second ground just to help it? I know its best to clean the proper ground but i am not willing to take off the manifold just to clean it.
Thanks
Old Dec 22, 2011 | 06:39 AM
mazdaverx713b's Avatar
Have RX-7, will restore
the grounds are a set of two matched wire sets with ring terminals on each end of the wire set. they are grounded under a bolt securing the solenoid rack to the housing.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
NickNac113
13
Oct 1, 2015 09:25 PM
