Best Coilover under $1000 (FD3S)
Old Dec 12, 2011 | 08:06 AM
Still_Ridin_Clean's Avatar
FL Best Coilover under $1000 (FD3S)
Im trying to figure out what coilover system to get. Ive been doing a lot of reading and Im not exactly sure what to get. I was looking at the Megan EZ coilover and Tein SS coilover. Im using it for street and occasional strip. I would like to stay in the $700 - $800 range but for an extra $100, there's like 10 other brands out there! So please help me out!
Old Dec 12, 2011 | 09:08 AM
Jason's Avatar
The one
If you are wanting to stay in the $700 range then Megan is not bad. The Tein SS use the stock top mounts and dont come with Pillow mounts.
I have a sale on the EZ or the street right now.
Old Dec 12, 2011 | 09:23 AM
ALPSTA's Avatar
Mission Impossible
Instead of buying cheap coilovers I would buy shocks and springs, however if you are saying you can get Tein SS for $800-900 then buy that.
Old Dec 12, 2011 | 09:43 AM
justturbo2's Avatar
Registered User
Bc coilovers are not bad too. It's about that price range
Old Dec 12, 2011 | 10:05 AM
I also want it to be a direct fit/bolt on. I didnt know the Tein you had to use the stock mounts. That seems kind of cheap. Does anyone one know if the Megan is a good ride? How low can they be adjusted with 17'' or 18'' wheels? I was leaning more towards these. Does anyone have these installed?
Old Dec 12, 2011 | 10:12 AM
dradon03's Avatar
Derwin
Not cheap just using the stock mounts reduces harshness. Tein are high quality products and are very durable.
I would agree with about posters a shock spring combo would give you better quality and will get you to the ride height you want. Coilover prices have jumped considerably over the last few years seems now the base price of midrange coilovers is 1500$.
Don't worry about the adjustability on the Megans if you go that wat it will be more than enough to get you are low as you could want.
Old Dec 12, 2011 | 10:49 AM
Zoolander's Avatar
Keep in mind that if you have to replace your stock top hats...then you have to add $240 to that shock/spring combo. And then add renting spring compressors to put them all together and the time......takes you right up to mid-level coilovers that you can just plug and play.
I bought Pettit's Stage II....working fine for me, but there's a massive thread on the pro's and con's of these somewhere in the suspension section.
Old Dec 12, 2011 | 11:06 AM
Sgtblue's Avatar
Urban Combat Vet
It's not cheap. And Teins are a quality coilover. The SS is probably just about right for your purposes. If your top mounts are in decent condition (and most are) using them is actually a good thing. Pillow-ball mounts aren't really needed with the FD suspension geometry and just add to NVH. That's probably why JASON mentioned that feature in his post.
For near your price range you might also consider a GROUND CONTROL kit. Those are also height adjustable and come with your choice of spring rate and shock depending on budget. ---> http://www.ground-control-store.com/...tion.php/II=42
I've been running GC for years with no complaints.
Old Dec 12, 2011 | 11:08 AM
IRPerformance's Avatar
Sponsor
Spent a bit more and get the Apexi EVX. They ride very well for the price. I believe the rx7 store has them for around $1050.
Old Dec 12, 2011 | 04:01 PM
FD3S2005's Avatar
SideWayZ The Only Way
These are the route i was going to go because they are cheaper than the tien flex i would like. i hear they have a very good ride. i believe papsmagu (simon) on the forums has these and likes them.
Old Dec 12, 2011 | 07:17 PM
got_hp's Avatar
ditto, i went with BC Racing
http://www.bcracing-na.com/products.php?view=BR_Type
you can get them for about $1k shipped, they are high quality (they manufacture for many other big names), and revalveable / rebuildable in the US.
Old Dec 12, 2011 | 08:40 PM
prrex4ever's Avatar
Now What?
I have these on my FD and I'm pleased with them. For street use they are great.
Old Dec 13, 2011 | 11:10 AM
HoustonMS3's Avatar
I know it's a little more than you wanted to spend, but I just picked up a set of stance coils for $1,100 shipped.
Old Dec 13, 2011 | 01:45 PM
97SupraTwinTurbo's Avatar
Trackstar motorsport
Koni yellow's over any cheap coilover. Once you are ready for real coilovers, spend some more $$$ and get quality stuff. You'll feel the difference & your vehicle will handle 10x's better.
Old Dec 13, 2011 | 02:00 PM
Rotank's Avatar
Slung all my rods
Best suspension you can get for under 1000$ is a set of Yellows with a ground control kit.
If your looking for something better than that, build your own konis, you will need to modify the instructions in the link to work with RX-7 components but the basic idea is still the same. You just need to use springs with the proper rate, and konis designed for the rx-7.
http://farnorthracing.com/autocross/konis.html
Old Dec 13, 2011 | 02:49 PM
juicyjosh's Avatar
Seismic Disturbance
CA
Originally Posted by Zoolander
... add renting spring compressors to put them all together and the time......
True, it will probably add an additional 40 minutes of working the springs. At O'Reilly's, it's a $50 deposit to rent spring compressors for 48 hours, but they refund the deposit upon returning the compressors.
I have the Flex Types with the solid "pillow" tops, but if I were to do it again, I'd probably want to try utilizing the stock upper mounts. No complaints here though After 7 years, my TEINs are still bright green, no rust, easy to adjust, and the car handles quite nicely.
For ~$1000, and given my experience with TEINs, I'd strongly consider the SS.
Old Dec 13, 2011 | 04:22 PM
Teins are great only because they're made in Japan but their spring rates are a bit soft & they don't produce both compression & rebound adjustment. For the money they're not bad though, I would start with Teins after Koni yellows.
Old Dec 13, 2011 | 04:37 PM
Supernaut's Avatar
Greddy s-types are around $1300. I'd save a bit more for that. IMO, if you don't have ideal road conditions around you, these are the best you can get.
Old Dec 13, 2011 | 07:05 PM
juicyjosh's Avatar
Seismic Disturbance
CA
Originally Posted by 97SupraTwinTurbo
Teins are great only because they're made in Japan but their spring rates are a bit soft...
It is a matter of opinion, but any of TEIN's *various* spring rates are plenty stiff for a 2800-lb. FD, and being *coilovers*, ridiculous stiffness is achieved by turning the perch and further compressing the spring. You can get it stiff enough to launch the car in the air over freeway undulations and do two-wheel balancing acts over driveways. And the ride would be a joke.
Incidentally, stock FD spring rates have been measured at 268-279/198-201 lbs. front/rear.
The SSs are 671/559.
My Flexes (and the Basics) are 559/448, and early on with the springs clamped down and dampening turned up, I've had a number of girls riding shotgun bouncing up and down because of my incredible stiffness
Old Dec 13, 2011 | 09:12 PM
purerx7's Avatar
Registered User
if you are interested i have a set of tein superstreets for 799, greddy type-s 975, tein flex for 1000 and a great set of hks hypermax 3 for 1200. Shoot me a pm, going used opens up a lot of great options.
Old Dec 13, 2011 | 11:46 PM
FD3S2005's Avatar
when i am looking for suspension im going to be contacting you then,
Old Dec 14, 2011 | 12:01 AM
jonnyrx7's Avatar
ROTARY PUNX
NONE....or Megan Track's. Still garbage....Tein....lol
Old Dec 14, 2011 | 12:19 AM
FD3S2005's Avatar
Any noticeable difference or noise or anything? whats the cons of not having the upper mounts?
Old Dec 14, 2011 | 12:59 AM
TinMan09's Avatar
Taliban Hunting Club
Personally I like Stance. If you dont HAVE to have NEW coilovers I'd look around for some Stance. I just bought a second set of GR+ coilovers for under $900 shipped. Theyre great coilovers too.
Old Dec 15, 2011 | 07:27 AM
Sponsor
Shock and spring combo is a waste of money in my opinion. Most people just slap them on and neglect to replace the dry rotted and compressed stock upper and lower rubber mounts. The car will then sit too low and cause all sorts of problems. You can expect to add $350-400 to the job by the time you buy all the mounts and isolators and for that price you can have a decent coilovers. The Apexi EXV ride very well for the price and have enough adjustability to cover everything from comfort, street driving, to moderate track use. The greddys are also a good option if you want to spend a bit more.
