Microtech LT12 20B Start-up map?
Old Oct 29, 2011 | 10:29 PM
berty's Avatar
I am getting an LT12 with an X6 igniter for my 20B Cosmo. I am after tips on how to set-up the start-up map. I am using all stock sensors (CAS, IAT, TPS etc) and I have 6 ID1000 injectors with after market rails etc. Any help would be appreciated.
Old Oct 31, 2011 | 06:45 PM
flaco's Avatar
it should start with the map in it.. then the rest is easy
Old Oct 31, 2011 | 07:58 PM
berty's Avatar
thanks for the reply - I was more concerned with setting up the injectors - is there anything I should be aware of running high- impedance injectors?
Old Nov 1, 2011 | 08:43 AM
Aaron Cake's Avatar
Engine, Not Motor
The Microtech doesn't care whether the injectors are high or low impedance.
Which, unfortunately, means that those nice ID injectors you have a kind of a waste of money. The interpolation method of the Microtech is so crude that you'll never be able to tune down to the fine PW that those injectors are capable of. And since you can't enter individual injector latency and other information, you won't be able to trim each injector as it should be.
Of course if this is just a drag car it really doesn't matter. On a street car, it's going to be hard to get a smooth and economical tune.
Old Nov 1, 2011 | 11:09 PM
berty's Avatar
Thanks alot for the info.
Given that I haven't been able to drive my car since July, I am just looking forward to being able to take it out for a spin.
Old Dec 24, 2011 | 08:20 AM
stezhead54's Avatar
did you ever get it running?
Old Dec 29, 2011 | 06:43 PM
berty's Avatar
I'm just doing the last of the wiring now. When I first got the car, I did some quick wiring jobs that are functional - but don't look the best. I am taking this opportunity to clean up a lot of the old wiring and ensure that everything is done perfectly.
I should have my first start-up in about two weeks.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
