What type of oil to use in car?
Old Jul 12, 2002 | 02:52 AM
JaneRX7's Avatar
I talked to various people and some people tell me to use synthetic oil while others tell me it's bad fr my car. What should I use? I went to the local Jiffylube and they put in castrol, is that good?
Old Jul 12, 2002 | 02:55 AM
7-sins's Avatar
thats not paint....
I use Castrol GTX. Syn oil has been known to produce residue with the way it burns off. Regular dino juice works great, stick with it.
Old Jul 12, 2002 | 03:03 AM
MastaCow's Avatar
I just made the switch to Royal Purple 10w40 synthetic from Castrol GTX 10w30.
The more research I did regarding this issue, made me want to make the switch more and more. So far, everything has been good.
Noticably smoother, seems to run a little cooler.
Old Jul 12, 2002 | 03:04 AM
rynberg's Avatar
You trust Jiffy Lube with your 7? You have more faith in the minimum wage oil changers than I do....
Old Jul 12, 2002 | 04:43 AM
Chronos's Avatar
how can you tell whether or not it's leaving a residue?
I'd stick with the non synthetic 10w30
Old Jul 12, 2002 | 05:17 AM
jspecracer7's Avatar
1JZ powered
Castro 20 W/50 dinosaur juice...
Old Jul 12, 2002 | 07:20 AM
rotorbrain's Avatar
fart on a friends head!!!
do the search guys: https://www.rx7club.com/forum/showth...threadid=93809
Old Jul 12, 2002 | 07:44 AM
evot23's Avatar
Classy
Valvoline 20w50
Old Jul 12, 2002 | 07:58 AM
ttpowerd's Avatar
HARRRRRRRRR
https://www.rx7club.com/forum/showth...&highlight=oil
search button still work?
Old Jul 12, 2002 | 09:48 AM
MastaCow's Avatar
Granted, I'm not tearing my engine apart and checking.
I haven't heard of anyone having problems directly related to using synthetics-just people scared to use synthetics due to the Owner's Manual warning.
Old Jul 12, 2002 | 10:34 AM
tfhuth's Avatar
Considering what a simple procedure an oil change is, I could not agree more!!! I would NEVER let those clowns close to a car, yet alone an RX-7 jeaz. Tom
Oh, Castrol GTX 20w50
Old Jul 12, 2002 | 10:44 AM
ttpowerd's Avatar
HARRRRRRRRR
you might want to try 10w30. You are in a cold climate so the 20w50 might be a little 'thick'. Just a suggestion
Old Jul 12, 2002 | 11:37 AM
tfhuth's Avatar
Thanks tt.
Old Jul 12, 2002 | 11:45 AM
rotorbrain's Avatar
there is very good info on the thread above. check it out. i think youll be convinced
paul
Old Jul 12, 2002 | 11:52 AM
ArinX's Avatar
What temp and weight do you guys in southern cali use??
Thanks
Arin
Old Jul 12, 2002 | 12:58 PM
JaneRX7's Avatar
You guys are killing me. I have never worked on cars before in my life so I don't know how to do it
Old Jul 12, 2002 | 01:17 PM
MastaCow's Avatar
Thanks
Arin
I was using dino 10w30, now i'm using 10w40 synthetic.
Some articles I've read about dino oil say that the bigger the gap in the viscosities for a multigrade oil, the more junk they have to throw into it to try and stabilize it; therefore, try to get the grade that has the smallest gap between the weights.
Old Jul 12, 2002 | 01:22 PM
MaTT_FoULk's Avatar
earning these was better
Niether had I till I got my FC, but with a little help from my dad I have changed all the belts, the hoses, the oil, the coolant, and soon some brake pads with the help of a friend.
Old Jul 12, 2002 | 01:59 PM
tfhuth's Avatar
I bet one of these nice guys out there in Cali would love to come by sometime and show you how it's done.
Guys........ ??????
Seriously don't take your 7 to one of those quick lubes.
Old Jul 12, 2002 | 02:04 PM
ttpowerd's Avatar
HARRRRRRRRR
Jack up the front of the car.
Take off the oil filler cap (the one that says OIL)
Slide under the car and losen the oil pan plug
Put something under it to catch the oil with
Finish removing the plug and let the oil drain
Take off the oil filter (right in front of the firewall on teh drivers side)
Put a little oil on the new filter's o-ring
Put the new oil filter on and tighten
Put the drain plug back in the oil pan and tighten
Fill up your car with new oil via the oil filler neck
I put in about 3 1/2 quarts then put the cap back on
Crank and let run for a little while
Check the dip stick to see how much oil it registers
Add at least 1/2 quart more (in most cases)
Old Jul 12, 2002 | 02:06 PM
Crashunit's Avatar
MIA
Here's a better one.
Old Jul 12, 2002 | 02:07 PM
tfhuth's Avatar
Dose anyone have that soundbite from the Jetsons that would be great right now...... JANE, JANE, STOP THIS CRAZY THING!!!!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
andyvideopro
Aug 20, 2015 10:55 AM
