99 Spec turbos installed
Old Jul 7, 2002 | 12:28 PM
Tim Benton's Avatar
FD title holder since 94
I finally got the brand new (0 miles) 99 spec turbos that I got from Jesse Lau installed on the car, what a bitch of a job at that. After fixing a loose hose, the car is running like it did before, but "feels" faster. Having changed only the turbos, and now rough tuning for the fuel curve, I'll head back to the dyno with the same boost setting to see if the more efficient turbos mean lower charge temps, quicker boost response, more hp in the lower range, more area under the curve.
Last time on the dyno, 334 rwhp, 13 psi.
I'll tune the PFC for 13 and 15 psi with these turbos....since its only my weekend toy, I don't worry about wearing the turbos out at 15 psi since I don't drive the car alot.
Tim Benton
Old Jul 7, 2002 | 03:40 PM
rajeevx7's Avatar
2 FD's since '98
sounds great, nothing beats the personal, free, butt dyno to see how your mods improve your beast of a hardtop roadster!
Old Jul 8, 2002 | 08:51 AM
ttpowerd's Avatar
HARRRRRRRRR
let us know when you are going to the dyno
Old Jul 8, 2002 | 09:22 AM
laujesse's Avatar
Thrashing your Roy score!
Veteran: Air Force
Glad to here the "butt dyno" approves. I would really like to see your new numbers and a list of your mods. Jesse
Old Jul 9, 2002 | 09:25 PM
laujesse's Avatar
Veteran: Air Force
Were you running 334 your 93-95 stock ones? Or were the reworked?
Old Sep 9, 2002 | 02:58 AM
Qball's Avatar
Comp Yellow Mica
uhhhhhhhh... any updates.. i'm interested in a pair
Old Sep 9, 2002 | 04:07 AM
Tim Benton's Avatar
The 99 spec turbos make 12 psi about 200 rpms quicker (2800 compared to 3000) than my stock turbos. I didn't get to tune it in with the wideband yet, so before and after only show what rough tuning I could do with the PFC for the stock turbos and rough tuning (basically 3 runs with adjustments inbetween) with the 99 turbos. At the same boost level (12 psi) I was making 6 to 8 HP more to the wheels through out the entire run. I didn't get to run it on 13 psi since I was just working on the first setting which was still .82 to .84 psi. I've gotten a slipping clutch ow I'll need to address that before I go back and dial it in with the wide band.
Tim
Old Sep 9, 2002 | 11:25 AM
Rotarius Maximus's Avatar
Is the '99+ spec turbo manifold the same as all the other years?
-Rot
Old Sep 9, 2002 | 03:37 PM
Qball's Avatar
Comp Yellow Mica
yes.. i've been told they bolt right up with no modifications.
Old Sep 19, 2002 | 10:18 PM
93blackrx's Avatar
I'm going to get a set of the 99' spec turbos. Are they really worth it? I was thinking about the set from Pettit.
Matt
Old Sep 19, 2002 | 10:37 PM
Tim Benton's Avatar
I'd ask Jesse (laujesse2) about getting some. He'll more than likely have better prices than Pettit as well.
PM him and find out.
Tim
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
