Weird Knocking Noise - done searching
Old Jul 6, 2002 | 10:20 PM
209_rx7's Avatar
Just did some searching, found a few topics somewhat similar to the problem I am having, but nothing exactly related so here goes.....
My 94fd is my every day driver. Every day when I go to work I drive my car, letting it warm up a min or two before leaving. But I get this problem whether the car is warmed up or not, almost all the time.
When I am backing up out of my parking space from my apartment I have to turn the wheel to the right so I can angle out right, when I am backing up I notice this weird knocking noise that sounds like its coming from the rear of the car. It happends most of the time when I am backing up at an angle and sometimes when I turn at slow rolling speeds.
Any ideas? Thanks in advance.
Old Jul 6, 2002 | 10:55 PM
rajeevx7's Avatar
2 FD's since '98
sounds like your rear bushings. its got to be suspension related. on both my 93's i had to replace the passenger side entire suspension, everything, because they r prone to making this wierd clunking noise back there. i just replaced everything and the problem was solved.
Old Jul 8, 2004 | 04:29 PM
Graziano's Avatar
In the last month, I was getting the same EXACT experience as 209_rx7. I hear the knocking noise only when going slow and when making turns. The first time I noticed it was when I was backing and pullling into parking spaces. it's gradually getting louder.
209_rx7, what was the culprit and how much did it cost?? Thanks so much. Kindest regards, Graz
Old Jul 8, 2004 | 04:35 PM
Graziano's Avatar
Old Jul 9, 2004 | 07:44 PM
Graziano's Avatar
Sorry for the dbl post. Another thing I noticed with this knocking noise is that my emerency brake lever cable keeps getting stretched and it does not hold the car if parked on uneven surface. Two weeks ago, I tightened the cable but it is getting stretched again! Could these two symtoms come from one problem? I cannot park out of gear.
Any responses are greatly appeciated.
Old Jul 9, 2004 | 08:10 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
Knocking noise is probably from the pillow ball bushings. There are 6 of them in the rear...very common problem, do a search on them.
Old Jul 10, 2004 | 10:31 AM
Graziano's Avatar
Thanks PandazRx-7. Your right...A search revealed tons of information on these pillow bushings. I hope Malloy Mazda still has them for $35 ea. Thanks again.
Shainiac
Jul 17, 2019 02:20 PM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
83revival
Sep 3, 2015 10:42 PM
