Auto->5sp Swap - Parts list.
Old Jul 1, 2002 | 03:12 AM
SuperPhly's Avatar
I have an 84 Automatic 12a GSL. I will try to pull parts off a JY of same year and low miles if possible. So far here is what I know I will need:
1) Transmission
2) Shifter Assembly
3) Plastic Interior Trim
4) Shifter Boot
5) Clutch Assembly
6) Smaller Brake Pedal
7) Clutch Pedal
What I don't think I need:
1) Drive Shaft
2) Bell housing
Old Jul 1, 2002 | 03:19 AM
Keaponlaffen's Avatar
Don't forget about the clutch master/slave cylinder, all the lines, and some way to rig up the return springs etc on the clutch.
Old Jul 1, 2002 | 03:26 AM
gamble302's Avatar
roadkill hats rock
anyone know about modding the carb so it doesnt backfire on ya?
Old Jul 1, 2002 | 10:59 AM
79+80_rx-7's Avatar
flywheel??? do you have to have one to swap from auto to manual?? i thought you did...
Old Jul 1, 2002 | 12:12 PM
oh yeah... you have to swap the torque convertor out for the 5-speed flywheel.... duh, stupid me...
Jeff
Old Jul 1, 2002 | 07:44 PM
CrazyJoe12a's Avatar
You will need a new driveshaft. The 84 and 85 Auto and 5 spd driveshafts are different I believe.
Old Jul 1, 2002 | 07:58 PM
Manntis's Avatar
add to cart
here's the easy method:
1) remove the radiator cap from your car.
2) replace everything else with a separately purchased 5sp.
3) replace the radiator cap.
3 steps and you're done, no tools required!
Old Jul 1, 2002 | 08:02 PM
mar3's Avatar
Administrator
Make sure shifter assembly also means the bolt that the clutch pedal hangs off of. It's different than the one in your car now, trust me...the conversion is not that hard, manntis!! Don't scare this guy!! Also..
8) Crossmember from standard car...they are, indeed, different...
Azevedo
26
Mar 1, 2019 09:19 PM
