Does this 25g match my needs?
Old Jun 30, 2002 | 09:02 PM
setzep's Avatar
I'm looking at a 25G mitsu from BNR supercars. I'm looking for 350 RWHP from a stock port cosmo enigne but want room for some gains if/when i port. I'm thinking I'd want to run max of 15psi on the street.
Here is the specs on it:
Full TD07 25G cartridge
4" inlet compressor housing and v-band clamped to the turbine housing
17cm divided exhaust housing
He has welded on a flange to the turbine housing and also has a flange ready for a DP to be welded onto it that he will throw in.
the turbo has 8k on it.
Will this suit my needs? How much is this worth?
thanks
Cam
Old Jun 30, 2002 | 09:15 PM
setzep's Avatar
here are some pic's
Old Jun 30, 2002 | 09:17 PM
setzep's Avatar
compressor shot
Old Jun 30, 2002 | 09:19 PM
setzep's Avatar
turbine housing shot (sorta)
These were take a while ago before the flange was welded onto the turbine housing
Old Jun 30, 2002 | 09:34 PM
RICE RACING's Avatar
From the photos, and my eye gauge flow "machine" that should easily deliver the goods
Old Jul 1, 2002 | 03:08 AM
Silex's Avatar
"goods"
Old Jul 1, 2002 | 05:10 AM
jspecracer7's Avatar
1JZ powered
Re: Does this 25g match my needs?
thanks
Cam
TD-07...15 psi...350 rwhp...no problemo
Old Jul 2, 2002 | 04:42 AM
osdesigns's Avatar
You should be able to get 320-350rwhp around 15psi. But you probably have to look into a fuel system upgrade to compensate the extra air that is pumped into the engine.
Old Jul 2, 2002 | 04:47 PM
setzep's Avatar
I'm starting from the ground up with this project, fuel delivery will be taken care of. Putting in a cosmo 13B-RE into a FB kinda makes you re-engineer the whole car.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
