stupid coolant seals.....
Old Jun 28, 2002 | 10:13 AM
blu_gxl's Avatar
ok, well i have airation of my oil so i'm pretty sure my coolant seals are bad any other reasons that i might have airation though just to have a glimmer of hope?
thanks for the input
james
Old Jun 28, 2002 | 12:23 PM
blu_gxl's Avatar
Old Jun 28, 2002 | 12:51 PM
'Vert in Vegas's Avatar
Expain this one more clearly please.
Failed coolant seals cause overheating,
or coolant loss,
or perhaps oil and coolant mixing in the block (grey sludge),
or exhaust gas bubbling in the radiator.
But
"airation" ???.
Old Jun 28, 2002 | 01:13 PM
j9fd3s's Avatar
Community Builder
there is almost no way for the coolant to mix with the oil in a rotary. bubbles in the oil are normal, just change it more often
mike
Old Jun 28, 2002 | 01:19 PM
blu_gxl's Avatar
well i went to go look at the oil and smell it to check for coolant, and well it smells like gas! that would cause airation it's not just a small amount of bubbles it's a lot of them (i never knew the rotary made bubles). i am going to change the oil tomorrow and find which injector is leaking that's prob where i'm geting the weird idle and hesitation.
Old Jun 28, 2002 | 01:39 PM
wozzoom's Avatar
airation of the oil? Smells like gas? Have you flooded the engine lately?
Change the oil ASAP.
Old Jun 28, 2002 | 01:45 PM
picazo505's Avatar
Old Jun 28, 2002 | 01:59 PM
blu_gxl's Avatar
will do tomorrow and i did flood my engine a few times since i changed my oil, could this also be associated with my hard starting?
oh and j9 i change my oil every 1500 to 2k miles hope i don't need to change it MORE often than that.
Old Jun 28, 2002 | 02:04 PM
Sniper_X's Avatar
if this is the criteria your using, then you do not have a blown engine.
I have trouble disposing of my oil because it smells like gas.
All rotaries do.
Fear not.
Old Jun 28, 2002 | 02:20 PM
blu_gxl's Avatar
well i had lost alot of coolant (forgot that i had a leak at a coolant line) so i saw bubbles in the oil and having just finished engines(piston) i remembered oh bubbles in the oil means coolant in the oil. well, it smells a lot more like gas than normal and i am having a hard start problem and hesitation at high rpms and my idle is funke it will idle at 1k then drop down to almost 500 then sometimes it will drop below that i've adjsuted my tps to compensate but if i have the tps adjusted correctly then it just wants to die if i have it turned realy advanced so it will idle
Old Jun 28, 2002 | 06:15 PM
blu_gxl's Avatar
ttt
Old Jun 29, 2002 | 03:54 AM
blu_gxl's Avatar
Old Jun 29, 2002 | 01:52 PM
blu_gxl's Avatar
so no one knows what this could be? well i'm going to try something i believe it's the bac valve failed because i have a voltage drop while running so i will let you know if i figure it out
Old Jun 30, 2002 | 04:51 PM
Amur_'s Avatar
Refined Valley Dude
The oil pans for the TIIs have baffles to try to reduce air bubbles in the oil. Pick one up from a wreckers or order one on-line.
And I've NEVER smelled gas in my oil, either on the dipstick or in a drain pan after a change...
Old Jun 30, 2002 | 07:45 PM
blu_gxl's Avatar
well, it's ok i'm not to worried about that now since i have oil on my spark plugs. they were so black and chared and stuff that was prob. what was giving me the hesitation. the gas smell i'm atributing to the flooding but no matter i'm going to just drive it into the ground and rebuild it when she breaks, hope i can get enough miles to get a beater
LongDuck
Oct 7, 2015 08:12 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
musker
Oct 1, 2015 05:58 PM
