Boost
Old Jun 26, 2002 | 09:14 PM
EProdRx7's Avatar
Boost
87 TII ported wastegate, FCD, 3" exhaust and down pipe, no cat.
Qestion is how can I cheat the boost up a bit? I'm getting 6lbs now but would like more. Whatb is the safe limit?
Thanks in advance...
Old Jun 26, 2002 | 09:21 PM
Scott 89t2's Avatar
SOLD THE RX-7!
that is what a boost controler is for...
get a bigger fuel pump and rewire it. and you should be good till 10psi
get yourself and EGT gauge too.
Old Jun 26, 2002 | 09:57 PM
e=mc2's Avatar
With a free flowing exhuast without the cat, the car should produce more boost than 6lbs. The turbo should spike some boost. Before you raise the boost you should make sure your fuel requirements are met.
Old Jun 27, 2002 | 11:57 PM
Ryde _Or_Die's Avatar
When in your series of mods did you do the wastegate porting? The reason I ask is because without it you should be seeing more like 9or 10# if you have any kind of intake I would think. I am just looking to see how much boost you can drop by porting the S4 wastegate.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
