[3] 94 Touring Stock CD Player Removal
Old Mar 15, 2001 | 10:40 PM
hapa's Avatar
Rotary-
My cd player was a b*tch to get out. It actually was backstrapped with a screw that went through a really tight rubber plug that was mounted to the frame. I basically pulled apart the entire dash just to pull on the deck extremely hard. It finally came out but be careful with the plug on the back. good luck
eric
Old Mar 16, 2001 | 09:41 AM
David88vert's Avatar
r71's daddy
I know it's a distance, but if you will run down to Atl, I will get it out for you. It is a nightmare if you are not used to it. I have the proper tools and have done it thousands (literally) of times.
You have probably pushed the tool into far and spread the clips to wide to come out normally. that's what happens if you push them in too far. They can only be pushed in until you feel the click. If you used a coat hanger, you will not feel it.
sYnth.
Aug 19, 2015 06:27 PM
