Microtech lt10s with x4 and cdi ignition
Old Jul 26, 2010 | 04:57 PM
BLACK MAMBA's Avatar
FD Project
can i run my lt10s with the x4 box and a cdi unit at the same time , or do i need to remove the x4 box and use the gray ignition wires from the lt10 and hook them directly to the cdi box.
Old Jul 26, 2010 | 07:11 PM
elturbonitroso's Avatar
run them at the same time.
Old Jul 27, 2010 | 12:30 PM
FD Project
How do i wired them together, do u use the wires that come out of the x4 to the cdi, and do i need to change any settings on the lt10 like spark mode, firing and dwell, any other info, gracias pay
Old Jul 27, 2010 | 06:39 PM
you use the outputs from the x4 to the input of the cdi i think the sut ups stay the sames but im not 100% sure.
Old Nov 18, 2011 | 05:29 PM
hondahater's Avatar
spending too much money..
actually I've been looking into this because it's not very clear anywhere on the internet. I've found this link here (http://www.microtechefi.com/forum/viewtopic.php?t=31) from microtech that says if using a cdi box you usually don't want to use the x4 box because it turns the negative trigger into a possitive trigger and most cdi boxes work best off of negative trigger. They say just to pull the x4 box and set your dwell to 0.00. This is how I'm going to setup my ignition because I was noticing breakup at higher rpm with the hi-6 and x4 box. I'll also be going away from the lx92's on the trailing because I found the lx92's don't like to work right without a cdi on them.
Old Nov 19, 2011 | 10:50 PM
rx72c's Avatar
Top Answer: 1
never had any issues with the hi-6 and x4 box at 700rwhp up to 10 000rpm.
If you have break up, your issue is else were, bad plugs etc.
Old Nov 22, 2011 | 10:16 AM
hondahater's Avatar
did you have 4 lx92 coils? It looks like everything I've been reading about says the lx92 coils are cdi coils and if you plug the trailing up to the x4 without a cdi box it will kill the x4 box. I read in another post how big possitive wires you make for the coils so I'm going to do that because I know mine aren't that big. Also I'm gonna get some magnacore r100 or r80 wires. It's good knowing your still on the hear! Thanks for the help again.
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
