TurboXS Knocklite
Old Jul 18, 2010 | 11:01 AM
BDC's Avatar
BDC
BDC Motorsports
TurboXS Knocklite
http://www.turboxs.com/more_info.php?ID=212
Supposedly can use factory knock sensors. Has anyone ever used this before?
B
Old Jul 18, 2010 | 01:19 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
You'd be better off with the bosch-style sensor that comes stock in the J&S kits. I wonder if you could data-log it?
edit: there is an output on the knocklite, likely a 0-5v style or something. A nice alternative to the J&S setup that's for sure.
Old Jul 18, 2010 | 05:32 PM
BDC's Avatar
BDC
BDC Motorsports
Hmmm. Thanks for the reply, Trots. I'll look into it. Have any reason why not to use the factory knock sensor other than the fact they're factory and old?
B
Old Jul 18, 2010 | 09:43 PM
No, i actually have zero experience with the FD3S knock sensor, so I'm just blowing smoke out my ***. Personal preference I guess, I like the design of the bosch sensor that bolts through a center stud for picking up vibrations, and I have an FC, so I needed a knock sensor, it came with my J&S. The bosch unit is also tried and true on race teams using closed-loop knock sensing, although i'm sure there is nothing really wrong with the FD sensor.
Old Jul 26, 2010 | 08:56 PM
arghx's Avatar
rotorhead
We have no specific technical data on the factory knock sensor. That's reason enough not to use it. The product sounds good though. The knock learning process it goes through is similar to what OEM's use. An Evo has a complex knock learning algorithm with sensitivity that can be adjusted by reflashing the factory ECU.
Old Jul 28, 2010 | 10:04 AM
patman's Avatar
Resident Know-it-All
Pm xstransam, he is in cahoots with turboxs and he is an electrical engineer, so he should be able to answer some questions if he is still around
Old Nov 28, 2010 | 09:16 AM
indio84's Avatar
hey bdc you ever get around to using this? or anyone else?
and which Bosch knock sensor is the one everybody keep referring to? there is a bunch of them.
Old Nov 28, 2010 | 12:52 PM
BDC's Avatar
BDC
BDC Motorsports
Nope never did. Have been eyeballing something else I found on eBay several weeks ago. I'll post it up in another thread here.
B
Old Dec 8, 2010 | 10:38 AM
patman's Avatar
i have one but I haven't got around to installing it yet, i'll try to remember to post some impressions when I do.
f2racer
Oct 7, 2004 08:24 AM
JasonL
Jul 24, 2003 02:59 PM
Rotary Rx7 T2
Jan 7, 2002 12:21 AM
