weatherstripping
Old Jun 24, 2002 | 03:19 AM
Manntis's Avatar
add to cart
weatherstripping
the weatherstripping inside my door window rails is driving me nuts. As the windows are rolled up they tend to want to 'jump the track'. The left window does it only in the last cm or so before closing, but the right window is adamant on staying on the inside of the seal strip, not in the centre groove.
I'm thinking a solution would be new (and therefore not as pinched, warped, and otherwise distorted) weather stripping - comments or suggestions?
Old Jun 24, 2002 | 06:15 AM
mwpayne's Avatar
Admitted 'rexaholic'
Mine did the same thing. I got two regulators from a junkyard, fixed both windows perfectly. The problem seems to be the center pivot on the window regulator wears and gets lots of slop it it, causing windows not to track properly. You can get them from mazdatrix, but they are $$. Don't forget to lube them up w/ heavy grease. Hope this helps!
Old Jun 24, 2002 | 09:51 AM
crankit's Avatar
Just did both my window channels. Found it easiest to remove the glass when putting them in. But still had a problem jumping track if I rolled it down to far. So i took a round file and elongated the adjustment hole towards the front of the to make a tighter fit. Took white grease in a spray can lubed the channels and linkage pivots. Been fine ever since. I am glad I did this first before jumping into buying regulators.
Old Jun 24, 2002 | 09:56 AM
jeremy's Avatar
male stripper
ditto on that. i need to replace mine.
Old Jun 24, 2002 | 02:29 PM
Manntis's Avatar
add to cart
thanks people! I'm new to this forum but am amazed how helpful it is
Old Jun 24, 2002 | 04:48 PM
Manntis's Avatar
add to cart
BTW is the rail/stripping available from an aftermarket supplier, or is this one of those things where Mazda charges you a few hundred bucks for a piece of rubber?
Old Jun 24, 2002 | 06:02 PM
Manntis's Avatar
add to cart
Nevermind, the dealer only wants $33 for 'em
Old Jun 24, 2002 | 10:44 PM
mwpayne's Avatar
Right, weatherstripping is easiest to replace, do that first. If that no workee, find a junkyard for regs, they hit me for $75 for both. The yards only a mile from my house, and no other rex's within an hour from here.
Gotta pay for convienence, I guess.
Old Jun 25, 2002 | 12:40 PM
rotorhead's Avatar
check www.mazdatrix.com for weatherstrip. that's where i got mine and they tend to be a lot cheaper than the dealer.
Glazedham42
May 2, 2022 02:41 PM
Snook
14
Oct 1, 2015 10:56 AM
Glazedham42
1st Gen Archive
Sep 1, 2015 08:20 PM
cluosborne
Oct 2, 2013 01:50 AM
cluosborne
2nd Gen Archive
Jun 14, 2008 11:31 PM
