Gas Tank Fuel Line Help
Old Jun 23, 2002 | 02:42 AM
AFSOC_Commando's Avatar
I have an 80 RX-7 that I just picked up for Cheap!
It didn't have a gas tank, Well I got a good one and went to put it in... Here lies the problem...
There are 3 lines coming from the front of the car...
Fuel Feed
Fuel Return
Evap???
And also a small device mounted under the car with 2 hose barbs...
The Tank has 4 Hose barbs, 3 are metal and 1 is mounted at the highest point and is plastic...
1. Can anyone tell me which barb from front to back is for which line???
2. Can anyone tell me the hose routing for the 2 barbed device mounted under the chassis?
I can get fuel to the engine hooking the fuel feed to the second barb from the front of the tank, But is that the pick-up barb?
I hooked the return line to the first barb from the front of the tank which sits at the lowest point, The carb floods as if the return line has back pressure. From what I have read the lines must all be hooked up in the right order to allow the car to run and not flod the carb... Can anyone PLEASE HELP???
The Haynes manual doesn't show any layout, nor does the Factory book....
Old Jun 23, 2002 | 03:27 PM
Barwick's Avatar
SCCA Rookie
yeah the manuals are pretty useless.. as I remember when I pulled the tank off my race car, there were a few lines, the obvious ones went to the filler and the filler drain. Then the others I'm not 100% sure, are they different sizes?
Old Jun 23, 2002 | 03:57 PM
V8kilr's Avatar
i think jeremy is the man to talk about this,
he has enough experience
Old Jun 23, 2002 | 04:08 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah PM Jeremy
AFSOC_Commando
Do you want this carb ???????
Old Jun 23, 2002 | 10:26 PM
jeremy's Avatar
male stripper
ah ****, hahaha. the center of the solid three is the main. the plastic is hooked to the evaporative. i believe the lowest is the return line and the top goes to the rollover valve. i was lucky in that my lines were sort of "matched up" from time.
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
82streetracer
Aug 23, 2015 09:28 AM
