well guys.. Drivetrain problems
Old Jun 22, 2002 | 01:20 PM
Question well guys.. Drivetrain problems
I'm hoping some of you have had this problem. I was reading some prior posts and no one seems to know what is wrong. I have an 89 non turbo, pulled the egi fuse, cranked it, then put it back in and it fired right up. runs like crap but ok. i'm going to atf it today. Now here's my real problem. While the engine is running, I can shift into gear. When I try and push on my clutch pedal, it is SOLID. like, seriously. could my rear end be bad, would that be why i can shift into gears? or is it just my clutch. thanks for any input.
~midi
Old Jun 22, 2002 | 01:23 PM
banzaitoyota's Avatar
What Subscription?
explain further please
Old Jun 22, 2002 | 11:08 PM
What I mean is... The clutch pedal doesnt move, at all. It's as if the slave cylinder is locked up or something? It has fluid, and is bled and all that. Maybe the slave is locked into the disengaged position, maybe that is why I'm able to shift into gears while the car is running.
Old Jun 22, 2002 | 11:56 PM
'Vert in Vegas's Avatar
It sounds like your clutch is stuck in the 'pedal depressed' position.
This could be the slave cylinder is locked up (extended). Maybe from rust in the slave cyl. or a bad (swollen) flex hose. For troubleshooting open the bleeder and see if the slave cyl retracts.
How long since you drove it normally?
It could be a actual clutch failure.
Get under the car and take a look. It should be obvious.
Old Jun 23, 2002 | 03:11 AM
with the bleeder open I'm still able to put the car in gear while running, so.. well, i'll check on that flex hose tomorrow, and see what I can see and i'll check back. in the meantime, i'm pricing clutches
Old Jun 23, 2002 | 03:26 AM
SonicRaT's Avatar
Super Raterhater
Either the slave is locked, or your throw out bearing is stuck, or you fork is bent and jammed, or something along those lines, just look at the slave cylinder, does it look like the arm is extended out at all?
Old Jun 23, 2002 | 09:16 AM
You have eliminated the hose as a problem.
Go with Sonic's tips.
PinkRacer
43
Oct 1, 2015 09:13 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
