Throttle arm for Weber 45DCOE
Old Jun 21, 2002 | 07:49 AM
FPrep2ndGenRX7's Avatar
The reason I'm putting this in the 2nd gen section is all the traffic that comes thru here. Getting an answer in the rotary performance section could take a while.
Until I get the FI setup in my FP car I'll be using a carb. What I need is a picture of the throttle arm side of the carb so I can buy the correct throttle arm for my carb. Anybody have one or know the Weber part number for the correct arm or wheel on the Weber's that were modified for use on rotarys. I believe the carb was originally sold by Racing Beat.
Old Jun 21, 2002 | 08:10 AM
tims's Avatar
TWM Induction in Goleta, CA has crank arms for their throttle bodies. they should fit the weber or can be modified to work. other wise try Fast Freddy's in Santa Ana and see if they still have some parts for those carbs.
Old Jun 21, 2002 | 09:12 AM
www.piercemanifolds.com has everything I need I just want to get the correct one. I believe those carbs came with a throttle arm but I would like to use a throttle wheel like on the factory intake. They have some but I'm unsure which one to use and was hoping someone else had switched over. Anyway thanks for the other parts suppliers to try.
