how to run cooler...
Old Jun 20, 2002 | 03:43 PM
Unhappy how to run cooler...
question, how do i make the engine run cooler?
Old Jun 20, 2002 | 03:45 PM
rico05's Avatar
WTB S5 N/A FC
Redline Water Wetter, or Evans NPG. Add a fan. Shim the back of the hood up a bit. Move to Antartica
Old Jun 20, 2002 | 03:47 PM
Aaron Cake's Avatar
Engine, Not Motor
Fix the broken cooling system perhaps?
Get a new rad, or get your old one rodded out. Replace all hoses, new thermostat, and of course new coolant.
Don't use additives to combat an improperly functioning system.
Old Jun 20, 2002 | 03:52 PM
Mark S's Avatar
Why do you wnat it to run cooler? Is the car overheating?
It's a myth that a system with a cooler operating temp actually moves more heat energy. In actuality, the hotter you run you system (within the limits of your coolant) the more heat is transfered out of your engine. The temp differential between the coolant and the air is greater, so a greater temp drop can be achieved through the radiator.
The problem with this is it increases the chance of your coolant boiling. (or localized boiling) Read the writeup on pineapple racings web-site under Evans coolant for a better descriptiion.
Old Jun 20, 2002 | 03:53 PM
Mark S's Avatar
Exactly
Old Jun 20, 2002 | 05:13 PM
silverrotor's Avatar
RX-7 Chica/// Your posts are starting to **** me and I'm sure other RX-7 owners off!!! With the above and on another post "I like ninjas. Are you a ninja"? It seems you have nothing constructive to say! Get real or get lost!
Old Jun 20, 2002 | 08:42 PM
kristopher_d's Avatar
Two years ago a team at the Indy 500 (don't remember which team) had a motor test 15hp above any other motor from the same mfg with the same setup. The crew cheif said "I don't know what all the fuss is about. We hadn't run the engine at all, and everyone here knows that a cooler engine makes more power."
Get a colder operating thermostat if you want to run colder (assuming everything is running according to spec). However, I will say this. I am driving around with a stuck open thermostat. The car runs decently most days, but last week the temps were over 100F and for the first time since I bought the car, my engine temp was right in the middle, and boy was she smooth. If you are going to run at high RPM's for extended periods of time, you'll want to run cooler ust to keep your engine cool. If, however, you are going to be cruising at 4k rpm, leave your cooling system stock(or near stock). As for the idea that a hotter radiator radiates more heat, NOT A CHANCE. Unless your coolant reaches ambient air temp while passing through the radiator, there is no way the temp of the water will affect its ability to be cooled. Again, your car likes to run at stock temp, so encourage it to do so.
Old Jun 20, 2002 | 08:58 PM
banzaitoyota's Avatar
What Subscription?
Run an Efficient coolant such as EVANS NPG+, Pressure test the system first to ensure it is in working condition. Check your OIL Cooler operation (30% of the engines cooling). Make sure the fins are not clogged with crap. Make sure your air baffle/undertray is installed, Fan Shroud in place?
Old Jun 21, 2002 | 04:30 AM
Re: how to run cooler...
If you are overheating, you should look for things that are the cause first. Are you loosing coolant? water pump? air in system? clogged radiator? bad thermostat? radiator cap? One thing you should ALWAYS buy from Mazda is the thermostat. Other ones go bad after a few months sometimes. It's not worth saving a couple dollars. Those are typical signs that will cause overheating. If your temp gauge is running 3/4 or more, you should get it fixed before doing any more driving.
Old Jun 21, 2002 | 04:45 AM
Amur_'s Avatar
Refined Valley Dude
Fins not clogged with crap?
My rad fins have a nice layering of snot from a leak in the front p/s lines that I used to have (patched it.)
Care to recommend a way to clean it without damaging the fins? Yup, I have compressed air to blast it with, but I'm wondering if there's some stuff I can spray it with first to loosen up the goo. Fantastik? Scrub-Free (meant for bath/shower)? I don't want to pooch the metal or the fins.
Old Jun 21, 2002 | 05:28 AM
Poppinrex7's Avatar
mine runs very cool, im running a k2rd radiator with a black magic electric fan, everything on the underside intact with no fan shroud....
-mark
Old Jun 21, 2002 | 11:11 AM
Mark S's Avatar
I Didn't say anything about power levels.
A colder operating thermostat will move LESS HEAT ENERGY from your engine like I said in the first post. It's the temprature differential between the coolant and the outside air that cools a radiator. If my coolant is 1 degree above ambiant air temp, what's the most I can cool the water?
1 degree assuming a perfect transfer of heat. If my coolant is 50 degrees above ambient air temp, I gaurentee you will get more than a 1 degree drop.
The temprature drop is the ammount of HEAT ENERGY removed from the motor. I learned this from a friend whos been auto-racing for 30 years. A radiator is just a heat exchanger.
Don't mistake the temp of the air charge for the temp of the engine. A cooler air charge will always make more power. The Indy car your speaking of made more hp because of a cooler intake charge as well as the ability to advance the timing of the engine.
As for what temp your engine will run best at, kristopher_d is right, the stock setting is best. But only because the engine ecu has been optomized for that temp. That optimization is mostly due to the effectivness of the coolant media.
As for overall thermal efficiency in an engine, higher temps are best, if the car has been optomized to run at that higher temp. However, than you get into other problems with engine longevity etc.
The reason I wanted to reply was to prevent you from going to a cooler thermostat, (or running a stuck one like kristopher_d ) because youu will move less heat from the engine if you do so.
Old Jun 22, 2002 | 11:12 PM
hi, it runs between 180-210. but once i go above 5K it reaches around 230...i was just curious as to whether or not i should invest in a new waterpump or just get some new coolant...thx
Old Jun 22, 2002 | 11:38 PM
darkwaveboi's Avatar
Need donor car in Fairfax
it sounds a small bit like the water pump belt is slipping. Has the belt been changed recently? Are you running the air pump?
when was the last time you had your coolant flushed?
Have you checked your fan-clutch?
Jeff
Old Jun 23, 2002 | 10:59 PM
im thinking redline water wetter is the way to go...i dont need a big mod, just to run slightly cooler...
Old Jun 24, 2002 | 12:20 AM
J-Rat's Avatar
Alcohol Fueled!
You may want to look at the thermostat first. If your staying cool at idle levels, and then heating up at high revs, your thermostat may be stuck open. Some thermostats default to the open position when they fail, which is fine for city driving. But at high revs, the water doesnt stay in the radiator long enough to get cool. Also, something to consider, if you are seeing temps in excess of 230, your coolant should be audibly boiling when you shut down your motor. If it isnt, might want to check out your sending unit. Lastly, I SWEAR by the coolant additives (not all of them). They break the surface tension of water, and help it flow more efficiently.
My .02
Rat
Old Mar 17, 2003 | 06:24 PM
never use water wetter . after using that **** my car almost over heated going to school i`m gona do a rad flush tomorow so yeah if i over heated it the car is for sale . and i want to sue redline .
Old Mar 17, 2003 | 06:37 PM
eViLRotor's Avatar
Brother of the Rotary
I'm a Ninja!
Are you....?
Old Mar 17, 2003 | 06:43 PM
Aaron Cake's Avatar
Engine, Not Motor
Water wetter works fine. In fact, I am convinced that it is the ONLY additive that actually works. You did something wrong and/or stupid.
Old Mar 17, 2003 | 06:53 PM
eViLRotor's Avatar
Umm, yeah.
I'd have to agree with Aaron. I have never heard of WW doing anything but reducing coolant temps.
Supposed to work best with a 70/30 ratio of Water and EG...
Old Mar 17, 2003 | 08:35 PM
Steel's Avatar
I'm your huckleberry..
come summer, im going to an 85% water mix, with some WW. Dont forget that water itself is the best liquid for heat transfer.
Old Mar 17, 2003 | 09:38 PM
JDMkamikazeeRX's Avatar
Question here. On my car(88 N/A) I blew the rear rotor. I am still able to get my car started and running on the front rotor. However, the engine will start to overheat after of only 15-20 min of idling. I do not see any coolent leaking, the hoses are very warm to the touch. Just wondering what if anyone had any idea what this could be. My new engine is on the way, and I plan on replacing the thermo, hoses, and boiling the radiator clean. I most wanted to see if anyone had an idea what it could be right now, also could I damage anything right now with my car running hot(I dont car about the engine). Finaly, I never had a problem with overheating before my engine blew. Also my car was sitting for about 2 months, I started about 3 times durring those 2 months.
thanks
~Anthony
jsotelo's Avatar
Water Wetter rox.. don't know how but it works..
Old Mar 17, 2003 | 09:51 PM
mrb63083's Avatar
aluminum radiator is a great start.
