do I need more fuel ??
Old Jun 19, 2002 | 12:00 PM
new recruit's Avatar
87t2 with 3"down pipe and mid pipe and cat into stock mufflers. 8psi boost ,sometimes 9-10 (cold air) mixture gauge pins rich when I nail the gas. No fuel mods. Is this ok??
Thanks
Old Jun 19, 2002 | 05:26 PM
Silkworm's Avatar
Has been.. hangin' around
Probably not a good idea, running lean is typically what kills these cars.
PaulC
Old Jun 19, 2002 | 06:58 PM
If the mixture gauge reads rich does that mean its rich enough?
Old Jun 19, 2002 | 08:30 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no the air/fuel gauges are pretty useless... 8psi is probably fine. but 8-10 is pushing it. get a bigger fuel pump and rewire it and you should be fine
Old Jun 20, 2002 | 07:00 AM
Sounds good, but last time I priced a pump it was $500. It was a holly, I know there is other brands. Whats a good pump to get? And a rewire? Ive heard somthing about that here before. What is required? Where I got the exhaust done They said I sould go pressure regulator. Whats better?
Thanks for your Help.
Old Jun 20, 2002 | 10:59 AM
SaabGuy's Avatar
I bought my Walbro 255lphp for around $125 from
www.autoperformanceengineering.com
Walbro is the sae as Holley. Holley just stamps their name on them
Old Jun 20, 2002 | 11:08 AM
Ryde _Or_Die's Avatar
No FCD? You need that now. I suggest ordering the walbro pump at the same time. I think we came to the conclusion that walbro fuel pump and fcd is safe to 10psi.
Old Jun 20, 2002 | 12:19 PM
The guys that put on exhaust diconnected the boost sensor. They said the computer will just read the air and exhaust sensors to get the right fuel. There is no fuel cut ,the only thing i've noticed runs a little richer than it used to. They also say to put a regulater in instead of a fuel pump. What do you think?
Old Jun 20, 2002 | 12:28 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Dude put the Vac line back on and don't go back to that shop!! your ecu is not retarding the timming now. that is just as, if not more important then adding fuel!!. get and FCD and a bigger pump. the reg is useless if your pump can't even flow enough. and the reg will just put more stress on the pump.
Old Jun 20, 2002 | 01:01 PM
WOW THAT MAKES SENSE!! Is that why it goes so fast? I found it funny. After I went and bought the oriface for the vacuum line and the tee for the boost gauge they ripped it all out and unplugged it. HERE WE GO AGAIN!
So now I won't drive it untill I fix it.
Thanks (things I needed to Know)
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
