overheating
Old Jun 17, 2002 | 10:18 PM
ech72's Avatar
Unhappy overheating
hey everyone....i wanna know if somebody can help me here. I have a 88 gxl non turbo, after i installed my RB pulleys my car get really hot only when i go over 90 miles an hour.. does anybody got the some problem before......i don't know maybe the radiator is cloged...any ideas...
eddy
Old Jun 17, 2002 | 10:21 PM
fc3s.org's Avatar
OG
Slow down
Seriously, did you re-time your car after installing them? You may be running a bit advanced. Was anything else changed while you swapped the pullies? Also, which pullies did you install? They have a few of them.
Old Jun 17, 2002 | 10:31 PM
ech72's Avatar
well... i just change the alternator and the main pulley...nothing else was changed...the car was running fine before i changed.....you may be right ...i need to check the timing..by the way how the timing should be...
the pulley is from racing beat and i guess is the only one they sell for n/a ...i think
eddy
Old Jun 17, 2002 | 10:41 PM
fc3s.org's Avatar
OG
Well, the RB main pully is designed for race cars. It underdrives your water pump 13-15% per theie webpage, so that means you are flowing less water then with the stock pully since it turns slower. It is meant for cars with upgraded cooling systems and cars that are at high rpm's so that the water pump won't cavitate. If you installed in a daily driver with no cooling mods, that could be the problem.
Timing should be set the same as stock. The pulley has the marks on it. You hook up a timing light to the leading plug wires and line up the leading mark by adjusting the CAS, then repeat the steps for the trailing. A full explanation is availible in the factory service manual, which is availible for download on my site under How-To's then manuals.
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 25, 2015 09:41 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
erevos
Sep 15, 2015 09:19 AM
