Haltech Secondary injectors not turning on
Old Feb 21, 2010 | 08:11 PM
SE\/EN's Avatar
Still Waiting.......
Hey guys, I am having a hard time figuring out why my secondary injectors are not coming on. I have searched the site but cannot find anythng that has helped me.
Here is some info:
850ccx2 primary
1680ccx2 secondary
Injection setup is:
Injecors enabled
Batch mode
Staged injection enbled with staging bar at 13 and in common mode
Ignition devide 2
Fuel Scale 100%
Injection angel end of injection
Have not done anything with trims everything is at zero.
I am using injector outputs 1,2,3,4 with 1,2 primary and 3,4 on secondary.
Am I missing something here??? I have tried to move staging bar up and down but as soon as the car reaches whatever staging point I have it set at, it goes very lean and falls on its face. The injectors were working fine until the ecu change. I am hoping that it is not the drivers What do you guys think?
Thanks in advance
Roky
Old Feb 23, 2010 | 12:29 PM
SE\/EN's Avatar
Anybody have any ideas??
I took the injectors out and had them tested, everything check out there. I have 12v at all the injector clips via red wire, and checked continuity from ecu connector pins to each injector clips and everything checks out there also. Is there anything I am forgetting or have not checked, or do I have something set up wrong in the e11?
When the injector drivers go out in the ecu, how do they go out typically? In pairs, groups or just one at a time?
Thanks
Old Feb 23, 2010 | 05:56 PM
C. Ludwig's Avatar
www.lms-efi.com
Change the injection mode to sequential.
Old Feb 23, 2010 | 09:43 PM
SE\/EN's Avatar
Wow do I feel dumb!!! I read in the manual that it needed to be setup in sequential, but was advised differently. I guess they wright manuals for us for a reason.
Thank you for the help ludwig.
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
