Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
porting a 13B
Old Feb 16, 2010 | 11:22 PM
Jakesrail's Avatar
porting a 13B
I will start off by saying that I am am running a 86-89 N/A13b with megasquirt II. the motor is in a sand rail. I am wanting to port the motor, but I was wondering, do I need to buy the whole $800 rebuild kit with the apex seals, or is the $150 gasket set enough. is it common for people to port the motor with only the gasket set? thanks.
Jake
Attached Thumbnails porting a 13B-12137_1281998209724_1223148495_832189_3791980_n.jpg
Old Feb 17, 2010 | 01:25 PM
levelzero's Avatar
once you have the keg apart you can measure the seals to find out if they should be replaced. If you have good compression now then chances are they will be fine and well within spec.
Old Feb 18, 2010 | 11:57 AM
j9fd3s's Avatar
Community Builder
the smart guy would pull it apart, measure everything, and replace whats needed.
Old Feb 18, 2010 | 06:57 PM
fidelity101's Avatar
Rallye RX7
tedious, but worth it.
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
mulcryant
Sep 9, 2015 05:24 PM
Ian_D
Sep 6, 2015 10:38 PM
