Im Freeeeeking Stumped Here...need Advise Guys....
Old Jun 16, 2002 | 11:11 AM
i want to purchase a air fliter systems....the ones that are cone shaped....they say it increases HP by 5-10...do i still need to keep the sensor, if thats what its called in the car still.....i think its located under the air filter holder....any suggestions as to what has to be done hooking this thing up...
Old Jun 16, 2002 | 11:16 AM
Aaron Cake's Avatar
Engine, Not Motor
Remove stock airbox, install cone adapter, install filter, start car. Shouldn't take more than half an hour.
rico05's Avatar
WTB S5 N/A FC
Just get a K&N cone filter, and stick it on the AFM. What year is your car?
Old Jun 16, 2002 | 11:34 AM
Ryde _Or_Die's Avatar
Its a 10 minute job. If you have an 86-88 you need to buy the afm adaptor:
Go to intakes and then its the last item.
Old Jun 16, 2002 | 04:14 PM
RETed's Avatar
Re: Im Freeeeeking Stumped Here...need Advise Guys....
Yes, the stock ECU will not run without the airflow meter.
-Ted
Old Jun 16, 2002 | 04:24 PM
rxseven's Avatar
Special Dark
5-10 hp increase is wishful thinking. More like 2 HP maybe, in cold weather, or a loss of a couple of hp if you are not going to make a cold air box.
Old Jun 16, 2002 | 04:28 PM
cold air box? whats that....btw, ive only had my rx for about a week..so im stilll learning....i need info as simple as poss...
Old Jun 16, 2002 | 04:31 PM
another thing can i do take my air pump out without affectign performance (HP/boost)
Old Jun 16, 2002 | 04:52 PM
rxseven's Avatar
Special Dark
Honestly, if this is the first mod and you just got the car, you will waste your money. That adapter costs like $20.
The open cone filters will suck in hot air under the hood. It's like 1-2% decrease in power for every 10 deg rise in intake air temp.
You could just remove the precats and have a downpipe made fairly cheap and it will be a better mod.
Old Jun 16, 2002 | 05:08 PM
RETed's Avatar
I guess you have conveniently forgot the increase in CFM flow over the stock air box which minimizes the heated intake temps...
Sure, the exhaust is going to give you (better) gains, but it's no where as cheap or easy to do as a cone filter conversion.
-Ted
Old Jun 16, 2002 | 05:16 PM
NZConvertible's Avatar
I'm a boost creep...
That's why you should always install a heat shield and cold air ducting at the same time. If you do this right, it's worth every penny.
Old Jun 16, 2002 | 05:21 PM
rxseven's Avatar
Special Dark
Yup, a heat shield will be necessary. As for the downpipe, i am pretty sure any muffler shop will make and intall one for less than 50 bucks, if the state of georgia is not **** about emissions that is.
Old Jun 16, 2002 | 06:26 PM
i ahv enot ordered the cone filter yet...i wanted to hear fom you guys out here 1st before i do anything.....i take it that someone who tries to modify anything would be foolish to do so w/o feedback here....thanks
Old Jun 16, 2002 | 07:02 PM
I KNOW I say an artical SOMEWHERE on how to make a cold air box/shield! I would just do a search to find it. It did look pretty easy! Anyway I DO have to agree with RETed and his advice does sound logical!
Old Jun 16, 2002 | 08:27 PM
silverrotor's Avatar
Perhaps this will help. http://www.fc3s.org/ click under engine than click again under COLD AIR BOX.
Wozzom had an excellent How-To for Series IV's. Don't know where It disappeared to though.
Old Jun 16, 2002 | 08:31 PM
dre_2ooo's Avatar
its spelled ADVICE goddamnit
Old Jun 16, 2002 | 08:35 PM
i just got my mazda.....the terms are greek to me...
what is series IV
what is FC
what is NA
what is FC3S
or any acro. i missed
i know i spelt it wrong after is sent it....appreciate the look out though
Old Jun 16, 2002 | 08:45 PM
AreExSeven's Avatar
Huh?
what is series IV
what is FC
what is NA
what is FC3S
FC / FC3S - Second generation RX-7. This number / letter combo is obtained from the Chassis and VIN. It is common among all second gens.
NA - Normally / Natually Aspirated. No forced induction (ie. turbo, supercharger)
Series IV - 86-88 Rx-7 (89-92 are Series V)
Old Jun 16, 2002 | 10:14 PM
PlayinW/Wankel's Avatar
Will someone please tell me where I can get the adapter for a K&N cone filter for my S4. I cant seem to find them anywhere. Or does anyone know the dimensions and I will make my own. thanks
eplusz
15
Oct 7, 2015 04:04 PM
Zinraf
Oct 1, 2015 01:09 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
RuffRx7
Oct 1, 2015 03:08 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
