Noise?
Old Jun 16, 2002 | 01:21 AM
BATESEL's Avatar
Angry Noise?
Greetings, and good evening.
I'm here to ask about this horrible rasping noise coming from my 1985 12A powered Rx-7. I have no clue from where it is emanating, and would appreciate any help that you can offer.
I've changed the air filter myself, and most of the more accessible parts have been replaced within the car's lifetime.
Old Jun 16, 2002 | 01:28 AM
Keaponlaffen's Avatar
is it coming from under the hood, from the rear end, from the wheels, from the radio... does it sound like a freight-train, a leer jet, a mouse, a file on hardened steel...??? Give us a bit more help...
Jeff
Old Jun 16, 2002 | 01:33 AM
BATESEL's Avatar
Thanks for replying.
It's coming from the air filter's housing.
Old Jun 16, 2002 | 01:43 AM
crankit's Avatar
check your coasting valve
Old Jun 16, 2002 | 01:47 AM
does it sound like a duck getting sucked into a shop vac in the middle of a tornado? If so, do a search for "Shutter Valve". if the shutter valve pulls at idle, it's bad... I don't have the pic showing which hole it is under the air filter top though... it's around here somewhere.
Jeff
Old Jun 16, 2002 | 01:49 AM
BATESEL's Avatar
That wouldn't be controlled bu one of those vacuum contolled solenoid valves next to the air filters housing. would it?
Old Jun 16, 2002 | 01:51 AM
ummmm... not too familiar with the emissions control.... why? did you remove the rat's nest?
Old Jun 16, 2002 | 01:53 AM
BATESEL's Avatar
It's not quite that loud. It's more of an unpleasant asthmatic rasp. It's only audible at idle.
Old Jun 16, 2002 | 01:55 AM
nevermind, I just saw your other post....
do you have a/c or cruise? if not, remove the whole rat's nest, plug off all the holes, and call it a day... oh, and remove the air pump, acv, and make a bloack off plate for the acv... if you don't know what I'm talking about, sorry, I'm just assuming you know a bit about rotarys. Do some searches on what I just said (acv, air pump removal, and rat's nest) and you'll learn a lot. If you live in a smog-controlled state (i don't know anything about emissions) then ignore everything I just said.
I would say check your shutter valve... it makes weird noises at idle if it's bad, and it sucks air through if it's bad.
Jeff
BATESEL's Avatar
No... I assume the rat's nest is that tangle of tubes and wires next to the air filter. Part of the plastic housing on that things body broke off. Now one of the hoses isn't connected.
Old Jun 16, 2002 | 01:57 AM
oh, is your car carbed, or fuel-injected? if it's a carb, are you sure it's not just normal venturi effect sound (sounds like a little sucking sound, like when you suck on a straw at eh end of a glas)
Jeff
crankit's Avatar
goes up the back side of the air cleaner by the idle compensator. yes it does come from the rats nest at least the vacuum for the shutter valve does. tried to block the vacuum before the shutter valve and it ran like crap. So ended up pluging the hose that went to the air cleaner. Been fine ever since.
Old Jun 16, 2002 | 01:59 AM
BATESEL's Avatar
I'm sort of ignorant about my cars engine, that's why I'm here. I'll do those searches, thanks for your help.
Old Jun 16, 2002 | 02:01 AM
BATESEL's Avatar
It's carb, but it's not normal air intake noise.
Old Jun 16, 2002 | 02:08 AM
crankit's Avatar
With the car running take the top off your air cleaner and see if the large hose that goes up to it in the rear is sucking air. If it is plug it.
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
