Power FC Disable O2 sensor?
Old Jun 14, 2002 | 03:24 PM
shawnk's Avatar
Perpetual Rebuilder
Question Disable O2 sensor?
Single turbo using a power fc with all the required mods and removed all emissions stuff including air pump (for track purposes of course) can I disable the O2 sensor in power fc? Should I? I suspect mine needs to be replaced but do I even need this?
Thanks,
Shawn
Old Jun 16, 2002 | 09:48 AM
shawnk's Avatar
Perpetual Rebuilder
Someone should know this...I have seen a few posts saying they had disabled it but no definative answer. Anyone? Do I need to post this somewhere else in the forum?
Old Jun 16, 2002 | 10:45 AM
rotorhead333's Avatar
I have shut mine off, I have noticed that w/ the O2 turned on that it tries to lean the mixture too much from what you have it set at in the PFC. I'd say, if you are racing it, leave it off. If you are cruisin around town, go ahead and turn it on for added clean up of emissions. If you think you need a new one and it's not working correctly, keep it off.
I always thought mine ran better w/ it off, probably cuz it's running rich like it should. Hope this helps.
Old Jun 17, 2002 | 08:26 AM
shawnk's Avatar
Perpetual Rebuilder
thanks for the reply...anyone else running with it off?
imitek
Sep 22, 2015 11:29 PM
rotor_veux
Sep 19, 2015 07:13 PM
