help someone
Old Jun 13, 2002 | 09:30 PM
help someone
my car ran out of gas in my 88 non turbo rx-7.....when i put gas into it...it wont start....i changed the spark plugs coz someone told me that if gas got on the plugs then it would be fouled out, it still did not start...i was not driving....it was parked in my driveway.....i started it this morning to move it and now it just wont start....please let me know what to do.....
Old Jun 13, 2002 | 10:37 PM
Icemark's Avatar
You may have burnt out the fuel pump, as the fuel pump needs gas to cool it.
Old Jun 13, 2002 | 11:05 PM
Roy James's Avatar
My cars louder than yours
i second that, did you put a jumper wire to prime the system? its a long shot, but it may work, but i doubt it
Old Jun 13, 2002 | 11:30 PM
where is the jumper wire located
Old Jun 13, 2002 | 11:38 PM
QC Motorsports
the junper is the female two inlet reciever next to the passenger side shock tower, and the afm. Its just kind of hanging there. You can find it in the Haynes manual.
Happy hunting.
Charles
if i had a manual that could of been a good idea...i knew i should of got one....this is my 1st rotary....only 3 weeks old
Old Jun 13, 2002 | 11:54 PM
QC Motorsports
Yeah. The manual would be a very good investment for ya man. It has helped me out alot. Same with the factory service manual. Good stuff.
Charles
Old Jun 13, 2002 | 11:57 PM
how do i prime the systemmmmthere are two wire hanging there...blue and yellow.....which one is it
Old Jun 14, 2002 | 12:10 AM
Silkworm's Avatar
Has been.. hangin' around
Yellow. Use a paper clip to jumper the two leads on that connector, then go turn the ignition on. Look for leaks!!!!!
PaulC
Old Jun 14, 2002 | 12:11 AM
no leaks....any other ideas....i need soem real schooling here...its still not cranking
Old Jun 14, 2002 | 12:21 AM
Icemark's Avatar
I thought you said it's not starting???? Now it's not even cranking over???
Old Jun 14, 2002 | 12:28 AM
its not starting but it is turning over.....cranking sorry i meant not starting
Old Jun 14, 2002 | 12:31 AM
Silkworm's Avatar
Do you have fuel pressure? Is the pump running? Check for 12V at the connector on the pump, if you have 12V, then the pump may have died, running in tank fuel pumps dry usually kills them from overheating (they use the fuel to cool them down)
PaulC
Old Jun 14, 2002 | 12:34 AM
i used a jumper and i heard the humming of the fuel pump...i think i may have fouled the plugs out by trying to start it over and over....do you think i should change them out.....i smelt gas from the exhaust
Old Jun 14, 2002 | 12:36 AM
Silkworm's Avatar
Oh, then yeah.. Search on flooding here in the 2nd gen forum, there's a few techniques on clearing that.
PaulC
Old Jun 14, 2002 | 01:15 AM
ive looked at most or all of them ithink on this topic....i tested the sytem by putting a paper clip in the yellow thing located on the passenger side of the car....i tried resetting the puter.....the only thhing i have not done which seems to work in most cases is tampering with the fuel pump....where is it and how do i do this....
Old Jun 14, 2002 | 01:17 AM
i changed the plugs out and it was drenched in fuel....so i put the old dry ones back in and it still wont start....they were new plugs(the old ones).....how do i do the fuel pump thing
