Opinion on Upgraded Rear End for 3 Rotor
Old Dec 26, 2009 | 02:42 PM
imtiaz's Avatar
Yesterday, the 25th of December, 2009...I shattered my stock rear end. So I have a couple of options... stock rear, kazz rear with upgraded axles, or what everyone seems to be using; the cobra rear end.
I believe its a good time for an upgrade. Im pretty familiar with the kazz set-up but im interested in the cobra rear and was looking for some input and whats entailed in this set up..
If theres another setup that can be used or that is better, please let me know..All opinions are appreciated.
btw, im making 580hp at 11psi and later down the road.. plan on raising boost.
thanks
Old Dec 26, 2009 | 08:06 PM
Lucrum's Avatar
You happen to have a dyno graph? If not what rpm are you making that 580 HP at?
Do know what your air/fuel ratio is?
TIA
Old Dec 26, 2009 | 08:53 PM
AnthonyNYC's Avatar
Stay tuned...
Hey Imtiaz,
Once I saw this post I knew it was you Read the thread below, it has a lot of info and you can start there before making a decision.
https://www.rx7club.com/showthread.p...highlight=kaaz
You need to start coming over to the drag section too
Anthony
Old Dec 31, 2009 | 09:51 PM
stevenoz's Avatar
before you do anything with the rear end just remember that all this will do is move the weak link to the tranny.
Anyway, if you wanna up the boost you should replace the driveline or buy a bunch of stock trannies
Old Dec 31, 2009 | 10:07 PM
Gurew's Avatar
i wish i had money to upgrade the tranny and diff
Old Jan 5, 2010 | 04:32 PM
ReZ311's Avatar
KM48 Burnout
T56 + Cobra rear end.
Old Jan 12, 2010 | 07:24 PM
dreed7235's Avatar
I am going to build a brace out of 3/8 in tempered steel that will not only give more stability to the front of the diff, but also cradle the rear of the diff as well. I will post pictures when I get it done. I am hoping that will save the case.
Old Jan 12, 2010 | 10:06 PM
ReZ311's Avatar
KM48 Burnout
The rear end will still blow up. I don't think bracing it is the problem. The design of the differential is not beefy enough. None the less, it would be interesting to see it fabbed up.
Old Jan 13, 2010 | 08:23 AM
dreed7235's Avatar
Yeah I know that the thin cast on the diff is the real issue. That is what I am going to try and remedy. I have a few ideas and will be happy to share them once I get this thing fabbed up. The true test will be once the 20b is up and running.....
Old Jan 15, 2010 | 12:33 AM
aeowner's Avatar
check out grannies speed shop in concrete washington they make bolt in solids for fb fc any configuration u want just ordered mine going with 3.90 ratio lsd true tracker
Old Jan 15, 2010 | 02:37 AM
Valley3's Avatar
Chewing on Tarantula
True but they don't have anything for the FD yet.
Old Jan 15, 2010 | 09:26 AM
ReZ311's Avatar
KM48 Burnout
Doesn't granny only offer solid rear axles? F-that!
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
