S4 vs S5 front fenders question
Old Jun 12, 2002 | 11:53 AM
Barwick's Avatar
SCCA Rookie
Are they the same? I've got a white '90 TurboII that's got a messed up drivers side front fender, and this junkyard around the area has a good white fender, but it's an '88 car. Will they match up?
Old Jun 12, 2002 | 11:58 AM
Icemark's Avatar
No, the series 5 T2 used a different fender than any other FC.
You will need to replace the fender with another series 5 T2 fender.
The part number is: FC17-52-211 for the T2 fender and FC01-52-211 for all other FCs.
Old Jun 12, 2002 | 12:06 PM
No7Yet's Avatar
Not quite sure about that Icemark. IIRC, the fender is the same, with the exception of the, uh, "bottom part" (under the rubstrip, behind the front bumper) and the rubstrip itself. I don't think that Mazda changed the actual fender itself...
I could be (and probably am) wrong, though
Brandon
Old Jun 12, 2002 | 12:13 PM
Barwick's Avatar
SCCA Rookie
crap.. you sure icemark? The S5 TurboII's have different fenders from other S5's too?
Old Jun 12, 2002 | 12:20 PM
Icemark's Avatar
Yep, call the dealer if you don't believe me... He'll give you those same two part numbers for a series 5 car.
One without the spoiler/ ground effects (the standard series 5 fender) and one for the T2 which came standard with the ground effects/Spoiler.
