super pro bushings- reuse/ max heat temp?
Old Nov 28, 2009 | 09:29 PM
muibubbles's Avatar
Bubblicious DEF.
so i already installed my super pro bushings last season but i want to powder coat my suspension pieces... is there a certain temperature they are resistant until? (can i bake the control arms etc with the bushing in em?)
also can i pop the bushings out, powder coat them, bake them, and reinstall the bushings? or does that ruin the bushings?
Old Nov 28, 2009 | 09:49 PM
ptrhahn's Avatar
I wouldn't paint/powder with them in, but I WOULD be interested in whether or not they are removable/reusable.
Old Nov 29, 2009 | 10:29 AM
dis1's Avatar
www.silverbulletrx7.com
I have recently been installing my superpro bushings. I can't see any reason why you couldn't remove and reinstall them. Just make sure you apply new grease.
Old Dec 1, 2009 | 10:00 AM
muibubbles's Avatar
Bubblicious DEF.
^^ thats what i thought... they ar pretty easy to pop out too since the bearing comes out seperately
Old Dec 12, 2009 | 10:43 AM
str8ryd's Avatar
Nearing Completion...
I just did this. Definitely remove the bushings before sending them for paint. I powder coated first and then installed the bushings.
Old Dec 13, 2009 | 10:50 AM
dgeesaman's Avatar
If they can go in they can come out.
However inspect the surfaces after removing them, if there is any scuffing on the bushing OD you might need to replace it.
Dave
Old Dec 16, 2009 | 11:01 PM
muibubbles's Avatar
Bubblicious DEF.
Dave
thats what i assumed just wanted to make sure i wasnt damaging anything before i did so...
